The camper thread! Pulling, using, equipment, maintenance!
#437
I can't wait for camping season. I went out and did some work on the new camper. Added some reinforcement to the factory stabalizer jacks. Than I test fitted some new leveling/stabalizer jacks. I'm going to build some mounts to drop them down 2-3 inches, and ties the two sides together. Just like how the factory ones are.
Here's a sneak peak.
These will allow better stability of the camper, because they can take a lot of wt off the springs. These jacks are rated at 7500 lbs each.
#438
So happy to see this thread back it means it almost camping time... nevermind.
https://www.ford-trucks.com/forums/1...n-january.html
#439
#440
#441
Looks great Dave! I've been planning to add a set in front of my axles to take out some of the frame flex but now you have me thinking "More is always better!" How are you planning to tie them together? I am looking to build some home brew 'JT Strongarms' to add to my factory jacks at the corners. I've read lots of comments from folks that use them that they really lock down any jack movement and eliminate trailer movement when setup. With a frame as long as our Jayco's I really want to do what I can to combat movement and frame flex.
You have a lot less snow around your rig than I do, I'm plowed in with about 2.5' in front of my hitch, of course I still need to do some hitch work, figures......
#442
We have had a easy year for snow this year, it's kinda nice and a pain at the same time.
#443
[QUOTE=hav24wheel;14077004]I wasn't going to tie them together, but I prob should do something so I don't end up bending them if the camper decides it wants to move one way or the other.
Dave,
I am a long time campground host in Wisconsin and over the years have seen many trailers roll away. I'll try and be as polite as possible when I say you have spent good money on your trailer, why cheap out with a left over brick to hold it in place? You need a set of expandable wheel chocks. I could not find a pic of our AS with the chocks in place so copied a picture from etrailer. A good set will cost you about $75.00 and it's money well spent.
My Airstream sits in the drive next to the garage. Every time it snows I plow all the snow away just in case we get time to travel, I would hate to have it snowed in.
Dave,
#444
I had about the same amount of snow on mine about a week ago. I shoveled it all off very carefully like I do every year. That is allot of weight on a weak TT roof. Plus when it melts off less chance of the water getting inside somewhere.
#445
#446
its spent its whole life with this amount of snow or more on it with no ill effects yet.
all that snow has pretty much melted anyhow such a screwy winter!
#447
Something is bad wrong with these last 2 campers. What in the world is that white stuff on them and the ground?
Here it was 62 degrees today, 68 tomorrow and going crappie fishing. And camping in 2 more weeks. But then again a week ago we were down to 0 and had snow. But Here in West Tn snow does not stay around for long then back to warm nice weather.
Pete
Pete
#448
Pete
Pete
#449
Dave,
Got them off eBay.
http://www.ebay.com/itm/Four-24-7500-lb-RV-Scissor-Leveling-Jacks-Trailer-NEW-/190359720267?pt=Motors_RV_Trailer_Camper_Parts_Accessories&hash=item2c5252d14b
#450
Used to use this all the time on our dock on the Tn river in cold Weather. But we had a 55 metal drum. And used the 5 gallon bucket in the homemade wooden john boat.
Like the beer art. My aunt used to make planes and stuff out of beer cans and sold them as fast as she could make them.
