Exhaust manifold removal... DONE, back on truck (Pics!)
I have a set of extractor sockets that can best be described as an easy-out on the inside. Spiral cut teeth that grab onto stripped bolt heads like in that picture. And they DO NOT let go. One of the best purchases that I have ever made. Makes childs play of stripped out nuts, bolts, allen head CV bolts, everything.
Might be worth your investment to get the job done.
Matco tools part number MBX13.
Saws & Cutting Tools, Bolt Extractors | Matco Tools Online Tool Catalog
http://lh3.googleusercontent.com/pub...mviRrQZZXOe1Ro
I have those same ones as well as this big one. Since I bought the set I haven't met their match.
That's what I did too. The bolts came out of the head with just a pair of vise grips. The problem was they had rusted into the manifolds. But with the manifold on the bench you can either heat them and hit them with a punch or air hammer. If that doesn't work they might have to be drilled out.
I took mine to the local napa and had them resurface the manifold so hopefully it will bolt up flush and not leak with out a gasket.
Well the blue wrench is still down, and here is what my truck though about those bolt extractors. It laughed.
<table style="width: auto;"><tbody><tr><td></td></tr><tr><td style="font-family: arial,sans-serif; font-size: 11px; text-align: right;">From Exhaust Manifolds</td></tr></tbody></table><table style="width: auto;"><tbody><tr><td></td></tr><tr><td style="font-family: arial,sans-serif; font-size: 11px; text-align: right;">From Exhaust Manifolds
<table style="width: auto;"><tbody><tr><td></td></tr><tr><td style="font-family: arial,sans-serif; font-size: 11px; text-align: right;">From Exhaust Manifolds</td></tr></tbody></table><table style="width: auto;"><tbody><tr><td></td></tr><tr><td style="font-family: arial,sans-serif; font-size: 11px; text-align: right;">From Exhaust Manifolds</td></tr></tbody></table>
#28
I will be doing this job as soon as my wife and I close on our first house soon I have leaks at all 4 points of the manifold to block, blown up-pipes and a van turbo Im gonna put on. Im Gonna get the ceramic coated up-pipes from Clay. I can tell from this thread its gonna be a PITA. I have a couple questions. If I can find a large belt sander and lay the manifold flat on it wouldnt that get it close enough to being flat? What can I do to make the job eaiser next time if I ned to take the manifold off, would never seize work or is that too much heat for it to work? I also want to sand blast the manifolds and paint them too, does anyone sell ceramic coating paint I can rattle can on there? Thanks
#29
How you been Casper??? its been a while.
#30
EDIT: Double post
