Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-17-2011, 08:49 PM
tly tly is offline
Garage is empty, add now
tly is starting off with a positive reputation.
oiling questions for 475cu in a L-800
I've got a L-800 boom truck and I'm trying to find the oil sending unit, I want to install a manual pressure gauge to see what the oil pressure really is, but I don't seem to be able to find the sending unit. I found one sender at the rear of the block but when I unhooked it the gauge still worked (showed pressure). Anyone have an idea where the oil sending unit might be located on the ford 475 cu inch engine? It doesn't appear to be anywhere on the top, front, or rear of the engine.
Thanks in advance for your ideas.
Tags
475, 475cu, engine, ford, location, motor, oil, sending, unit, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
