New to trailers - need some advice.
#121
#122
Well, the water tank fill hose is kind of loose in the trailer, so I jiggled it around and got the water to go in. Although, I thought that there was an air vent, like in this picture I found online. Shouldn't that mean that I don't need an air gap around my hose?
That's a minor problem, and I'm not too worried about it.
Must bigger is that I can't get the hot water tank drain plug to seal 100%. I wasn't having success with the normal thread tape, so I used some of the "Natural gas thread tape" which seems to be thicker and squishier. I did several wraps of that, and could barely thread the plug in, but I got it in, snugged it up, and left it connected to city water pressure for a few hours. There were only a few drops weeping out in that time, but I'd prefer no weeping at all . . .
This is probably "good enough", but it's going to annoy me.
See that hose for the vent in that photo? Took me a year to figure out why MY 5er wouldn't fill my fresh water tank!!! A mud dauber wasp had build a mud dam inside that sucker!!! Try to reverse flush that hose and you'll find your H2O fill problem!
#124
#125
Easy to check... just pull the end from the fresh water tank (if you can reach it - mine was located right in front of my face) and try filling it again. I could turn my water on full force and fill it. Be sure your water tank isn't already full tho..... it won't vent to the outside!!!
Steve
#127
Santiagoeford
01-07-2017 04:49 PM
griced
04-13-2009 01:53 AM
