2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
07 expedition eddie bauer air suspension switch
Old 04-16-2011, 08:03 PM
larson29's Avatar
larson29
larson29 is offline
where is the air suspension switch located because i want to lift it up to do an oil change at my work but i cant find the thing does any one know is it in where the oil reset button is or that panel under the glove box by the door anyone know?
Old 04-25-2011, 06:19 PM
Harley Guy's Avatar
Harley Guy
Harley Guy is offline
larson29 - it's an automatic function. It's a load leveling suspension, you can't use it to raise the truck enough to climb under it to change the oil. You can only turn it off or on. Whenever you jack the truck you need to turn it off. It's all covered in your owners manual...
B/R,
Randy
Old 04-25-2011, 07:49 PM
Hemlock10's Avatar
Hemlock10
Hemlock10 is offline
There was an system once upon a time that would raise the whole vehicle when you put it in 4WD, but the airbag system is strictly for rearend levelling. Here is an excerpt from the owners guide.
"The air suspension shut-off switch is
located on the left side of the trunk.
If this switch is in the OFF position,
the rear air suspension will not
operate."
Hope that helps.
Old 04-25-2011, 10:02 PM
larson29's Avatar
larson29
larson29 is offline
yah i found where it was you had to keep hitting setup until you find it and press the reset button which turned it off. and i work at auto shop as apprentice so i was going to use a car lift
TerranE
07-28-2017 06:14 PM
johnkn
2015 + Expedition & Navigator
05-09-2017 05:45 PM
kevintoupin
09-13-2016 09:29 PM
cd4e
2009 - 2014 F150
09-08-2015 02:11 PM
dwetopgun
1997-2006 Expedition & Navigator
03-29-2007 03:44 PM
Quick Reply: 07 expedition eddie bauer air suspension switch
