1972 F-250 Chassis dimensions
on
Is that a unibody F-100? From what I can find for specs is that they had a 114" and 122" wheelbase which doesn't match up to an F-250 which had a 131 and a 149" (crewcab) wheelbase. Ford never made a unibody with 4wd because in offroad use the body would flex too much and destroy it as the frame flexes. You could swap the front axle and transfer case to the F-100 to make it easier. I have seen one done that way here in Alaska.
rare unibody
Thanks for the reply. Best wishes to you on the project. The unibody pickups are extremely rare up here in Canada, I think it is because the roads were so bad up here in the 60's that people were worried that the unibody pickups would not be able to take it. I have only seen 2 around here, one was a Mercury, which is even more rare.
MrHandsome
12-16-2016 09:01 AM
Fshmn62
07-07-2014 11:12 PM
BobbyB247
01-02-2012 05:48 PM
