1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
P0012, Trying to pinpoint the cause.
Old 04-14-2011, 10:19 AM
fred.mason's Avatar
fred.mason
fred.mason is offline
Working on my 2005 f250 5.4L 3v.
Engine runs fine, revs up and sounds good. It has a slight miss when under acceleration. When I return from a drive the engine will stall as I coast into the driveway with the clutch pressed. When I start it back up the engine will thrash around and start the loud ticking from the pass side. I can give it fuel and rev up to around 1500 rpms and hold for a few seconds and the engine smooths out and returns to normal. I can make the engine go into this "thrashing" state by just turning the truck in the driveway. It seems that whenever the engine lugs that it has trouble recovering. I have just changed the timing chains and tensioners so I am sure it is nothing with that end. I do get the P0012 code and I am starting to suspect the phaser. I switched the vct solenoids around and the problem stayed with bank 1. I also tried driving the truck with both vct solenoids disconnected; It ran like crap but no stalling or thrashing. Would these be accurate tests to determine if the phaser is bad? Is there anything else that may cause this problem? Thanks
FoxNotch
13
05-14-2016 11:05 AM
f150guuy
2004 - 2008 F150
09-04-2014 12:59 AM
jtillery
1997-2006 Expedition & Navigator
02-15-2014 01:49 PM
C F Industries
2004 - 2008 F150
05-04-2011 05:56 PM
tomclem
2004 - 2008 F150
16
01-20-2011 10:11 PM
Quick Reply: P0012, Trying to pinpoint the cause.
