1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2003 EB 4.6L - P0171 & P0174
Old 04-13-2011, 05:48 PM
zcpro's Avatar
zcpro
zcpro is offline
Exclamation 2003 EB 4.6L - P0171 & P0174
Hey guys I'm new to the forum!
I have a 2003 EB 4.6L that keeps giving me the same OBD II Errors [P0171 & P0174 (system too lean on bank 1 & 2)]. It happens right after I put gas, I clear the codes and they come back after a few days.
Any suggestions?
I'd read that a PCV vacuum line hose/elbow needs to be replaced. Is this the same fix for my 2003 Expy? If so, does anyone know the correct part number? The one listed is for model yr 98-02
Thank you in advance!!
Old 04-13-2011, 08:45 PM
pdqford's Avatar
pdqford
pdqford is offline
Only if that is what's causing the lean codes.
First pull the elbow off and closely inspect it to see if it is causing a vacuum leak.
sailmfast
1999 to 2016 Super Duty
03-02-2013 03:09 PM
svfetter
11-21-2012 01:36 PM
srozing
01-19-2012 02:04 PM
Quick Reply: 2003 EB 4.6L - P0171 & P0174
