1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2008 F250 Steering Sticks
Old 04-12-2011, 12:43 PM
Sugars Pop's Avatar
Sugars Pop
Sugars Pop is offline
When driving 30 mph or more and I turn, the steering sticks but it does not occur every time. I thought it may be the steering dampner, so I replaced it, but that was not the problem. It also seems to stick if I'm driving 50 mph+/- and I have to apply the brakes at a traffic light. Once I stop at the light, it seems normal again. Noticed the other day the steering wheel seems to have to much play in it going straight so could it be the steering box needs to be adjusted(is this possible) to remove the slack?
Would like to trouble shoot the problem prior to dropping it of at the dealer to make sure I'm not taken to the cleaners.
Thanks
Old 04-12-2011, 02:05 PM
thomabb's Avatar
thomabb
thomabb is offline
The steering wheel has too much play and the steering wheel sticks? You can't adjust the gearbox for that.
One thing you can check pretty easily is your front U-joints. Park with the wheel hard to one side and the front hubs out. Reach around and turn the U-joint around a couple revolutions by hand. Feel for any binding. Also check for slop. I had a frozen U-joint that manifested itself as a steering issue. The wheel felt like it would bind up.
Old 04-12-2011, 02:12 PM
Sugars Pop's Avatar
Sugars Pop
My truck is a 2 wheel drive so are you referring to the U Joints on the drive shaft?
Old 04-12-2011, 02:16 PM
thomabb's Avatar
thomabb
thomabb is offline
My bad, I assumed you had 4wd. Please disregard my previous advise.
Get her to a shop soon. Something under there could be getting ready to let go. Or it could just be a cracked ball joint. Either way, she's probably not safe to drive.
Old 04-12-2011, 02:23 PM
Sugars Pop's Avatar
Sugars Pop
There is another person in Houston that I ran accross on a fishing forum with a 2008 F250 and he is having the same problem. He thinks it may be a flawed steering box. I know Ford has had some issue with steering boxes on older models and he is thinking they may issue a recall for these but I doubt that will occur.
Thanks for your input anyways.
Brandon150
2009 - 2014 F150
13
05-12-2017 09:20 AM
C21no1
04-12-2017 06:13 AM
100-10x
11-21-2015 01:34 PM
ryanschillinger
16
09-10-2014 08:30 PM
Jackson1991
1983 - 2012 Ranger & B-Series
05-15-2010 12:19 AM
Quick Reply: 2008 F250 Steering Sticks
