Oil in VC pigtails ok?
Old 04-12-2011, 10:56 AM
terrapin88's Avatar
terrapin88
terrapin88 is offline
Hey all.
Does having oil in the plugs for the gp's and injectors affect anything? I am replacing my VC gaskets, the uvch's and I have some new pig tails I could solder on but I am feeling lazy and wondering if I should bother to. My original pigtails have some oil in the connections that I could get out with a little effort. Should I clean them or replace them?
What would Johnny Cash do?
Chris-
Old 04-12-2011, 02:46 PM
427 fordman's Avatar
427 fordman
427 fordman is online now
If you have the parts, replace them. I hear the being lazy part, sometimes a guys that way, but I wouldn't cut corners here.
Old 04-12-2011, 03:07 PM
superduty4x4's Avatar
superduty4x4
superduty4x4 is offline
I'd clean them myself. With new valve cover gaskets and UVCH's you should be good to go. I don't like the idea of cutting/soldering the OEM harness but to each his own.
Old 04-12-2011, 05:08 PM
terrapin88's Avatar
terrapin88
thanks for the replies. I am somewhere in the middle between lazy/not wanting to cut into the harness, and just replacing them for piece of mine. I'll most likely replace them. Or at least the oiled up ones.
thanks
c-
Old 04-12-2011, 05:31 PM
MADVAN's Avatar
MADVAN
MADVAN is offline
Why is a solder connection bad?
OP
Oil in the connector can coke from the heat of the gp load.
Old 04-12-2011, 05:34 PM
superduty4x4
OP
The oil in the connector can coke from the heat of the gp load.
Its not, I would just rather not have to cut/solder the factory harness if it doesn't need it.
Old 04-12-2011, 06:54 PM
terrapin88's Avatar
terrapin88
thanks madvan I didn't think about that. It's not burned in there tho. Just a little oil in it I can clean out. I think I'll just replace.
