Fuel pump questions. Leaking diesel
ok so i replaced the fuel pump on my 95 on the top of the motor, but when i did it i did not know if the washer that goes around the big bolt that hold the two fuel lins, well does the washer go right on the bolt or does it go between the line and the pump, sorry its hard to explain. but anyway the truck is leaking deisel on top were the fuel pump is, i have the washer between the line and the pump now. is this the corest way or does it go between the bolt and the line, thanks
