Blue Oval Saga Pt. II-Michelle
#527
#528
Hey Wes, truck is looking good! where did you source that radiator support and how much was it? (if you don't mind me asking). In the spring I am thinking of putting a new one in and the radiator and new braided stainless coolant lines all around. Either that or a new rear tank, if I do the tank I'm thinking new frame crossmembers, taking the bed off and getting a good coat of por15 or similar product on everything. That is of course if I have no issues all winter, knock on wood.
#529
Got it off Ebay....
#531
#532
#534
#535
It's been another while since my last update but here goes..
The Engine Bay Power Point.
The wires have split loom on them now.....
And here's my engine bay worklight working off the power point..
- Re-Adjusted my Hurst Shifter (Was getting slop in it from bolts loosening up)
- Added an engine bay power point.
- Installed my CB radio
- Installed a new Power Steering Pump Hose (FINALLY)
#536
Even more work has been finished up on Michelle lately..
Fuse Panel before I installed the cover and added the split loom.
And the Battery Tray
- Painted/Installed a Diesel Auxiliary Battery Tray/ Wiper Fluid Reservoir
- Installed a Ford Ranger Engine Bay Fuse Block as a fused 12v source
- Cleaned up the wiring in the engine bay
#540
