swap out
Old 04-07-2011, 10:48 AM
72f2504x4hiboy's Avatar
72f2504x4hiboy
72f2504x4hiboy is offline
swap out
can u take a 5.0 from a 91 cougur and put it in a 96 f 150 with a 5.0
Old 04-07-2011, 03:41 PM
Conanski's Avatar
Conanski
Conanski is offline
Yes but you will have to transfer over the oilpan and pickup, complete intake system, timing cover and water pump, balancer and distributor, and accessory brackets and accessories from the outgoing truck motor to the new stripped down donor motor.
Old 04-07-2011, 03:45 PM
KevinGnWV's Avatar
KevinGnWV
KevinGnWV is offline
The village idiot.
So basically Cougar block and heads, everything else truck parts correct? Are there any pros/cons to one head over the other?
Old 04-07-2011, 03:55 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,173 Likes on 927 Posts
Both engines should have the same E7 cylinder heads.
Old 04-07-2011, 04:50 PM
KevinGnWV's Avatar
KevinGnWV
The village idiot.
Ok thanks. I wasn't sure if there were any differences in the valves, springs, etc. And if anyone else didn't know, now they do
Old 04-07-2011, 05:40 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Arn't the 5.0 cougar engines HO? And they have a differnt firing order than a regular 5.0?
Old 04-07-2011, 05:50 PM
Edgethis's Avatar
Edgethis
Edgethis is offline
HO is just the 351W firing order. I didn't think that all cougars had the HO.
