1988 150 5L EFI rough idle low vac back fireing
Old 04-06-2011, 02:20 PM
Bob Fletcher's Avatar
Bob Fletcher
Bob Fletcher is offline
1988 F150, approx 150,000 mi. seldom driven yard work truck. Had been running reasonably well until recently. Cat was removed years ago. EGR was disabled [sealed at port] also years ago.
Starts instantly but barely idles when cold. Somewhat better when hot. Vac about 9 in. at idle. Have used two cans carb cleaner looking for Vac leak. No results. With careful pumping of throttle, can get up to 2000 rpm, sometimes 3000 rpm. Vac drops to zero above 2000 rpm. Goes to 20+, momentarily, on deceleration. Severe back firing over 2000. No power. No codes other than the obvious, EGR. Have not, as yet, checked compression. Ignition looks good on all 8 but sounds like it is running on less than 8. Very rough with severe vibration.
Have no clue where to go from here.
Thanks for any help.
Old 04-06-2011, 09:57 PM
deeznuts822's Avatar
deeznuts822
deeznuts822 is offline
I would say the timing chain is probably loose,or has jumped time.
midgainc
37
08-07-2014 08:37 PM
donaldm
1983 - 2012 Ranger & B-Series
11-08-2012 08:05 AM
firewood truck
46
05-31-2012 08:41 PM
Bob Fletcher
04-06-2011 08:38 PM
Greg 79 f150
25
05-16-2005 04:24 PM
Quick Reply: 1988 150 5L EFI rough idle low vac back fireing
