GOOD MORNING!!
Old 06-06-2013, 12:51 AM
1975MudRat's Avatar
1975MudRat
1975MudRat is offline
Wow, thats f***ing dumb. I think you need to kick your land lord in the sack lol.
  #7562
Old 06-06-2013, 12:53 AM
Killgore's Avatar
Killgore
Killgore is offline
The landlord and I will probably have another talkin to tomorrow. He is trying to make the neighborhood into some uppity white neighborhood when we are in the middle of the damn ghetto. And lord help these hippies if they something about the oil slick under the truck as one will end up going through a wall
  #7563
Old 06-06-2013, 12:57 AM
1975MudRat's Avatar
1975MudRat
Hahaha damn city people don't understand trucks. Them hippies are more then welcome to climb under it and fix it. lol
  #7564
Old 06-06-2013, 01:00 AM
Killgore's Avatar
Killgore
Killgore is offline
I think it is the valve covers leaking rather than the main seal since it is leaking from the top down and the wet spot is no where near the rear main. I dont imagine that's too hard to fix, cant I just rtv that?
  #7565
Old 06-06-2013, 01:02 AM
1975MudRat's Avatar
1975MudRat
You can if you want. I would just torque them down. Valve covers are easy to deal with. If something is leaking just tighten them down and they usually quit leaking.
  #7566
Old 06-06-2013, 01:04 AM
Killgore's Avatar
Killgore
Killgore is offline
Well I'm going to spray degreaser over almost every damn inch of that motor and spray high powered jets of water at it to see if I can pinpoint something. Can you over torque the bolts?
  #7567
Old 06-06-2013, 01:06 AM
1975MudRat's Avatar
1975MudRat
Yea you can over torque em but just go til the get hard to turn with one finger then torque it one half turn and you should be good.
  #7568
Old 06-06-2013, 01:08 AM
Killgore's Avatar
Killgore
Killgore is offline
Okay I'll do that before I go pullin valve covers and layin down rtv. I swear FEs never seal with gaskets. I'm half tempted to rtv everything but the exhaust gaskets ... I also need to pick up a set of them
  #7569
Old 06-06-2013, 01:12 AM
1975MudRat's Avatar
1975MudRat
I sealed up everything with high temp rtv when I built my engine. I would save that set of gaskets clean em up and rtv both sides. I re use my valve cover gaskets when I'm at the mud runs. Right after I swap tires in the pit I take the valve covers off and check everything out. I only do that because every now and then I will come across a bent rod or the roller rockers are screwy. It just became a habit.
  #7570
Old 06-06-2013, 01:15 AM
Killgore's Avatar
Killgore
Killgore is offline
Well the problem with one gasket is it looks like it was just a piece of plastic with crappy holes cut in them. Almost like a patch job. The other one is fine, but id rather no exhaust leaks. Sounds better that way
  #7571
Old 06-06-2013, 01:19 AM
1975MudRat's Avatar
1975MudRat
Yea, Well then you might wanna go and get another set of gaskets. I don't like putting rtv on with no gaskets. I know that sounds weird since its gasket maker but I always put it on my gaskets to make it seal better.
  #7572
Old 06-06-2013, 01:22 AM
Killgore's Avatar
Killgore
Killgore is offline
Well I've heard not to use rtv on exhaust gaskets. If I take the headers out I'm also gonna paint them. I liked how the rustoleum road runner came out that hot rod did a couple years back, I'll probably do the headers like that. I love 70s street machines so that's perfect.
  #7573
Old 06-06-2013, 01:29 AM
1975MudRat's Avatar
1975MudRat
Oh no. I only use on thing on exhaust. It goes on like a paste and the once heats up it turns to a glass. I can't remember the name of it. I can look around in the shop tomorrow and see if I still have any and I'll give ya the name.
  #7574
Old 06-06-2013, 01:30 AM
Killgore's Avatar
Killgore
Killgore is offline
Okay that works. I'm sure the guys at o Reilly's will be sad when they cant call my truck the oily mess anymore. Silly Chevy drivers
  #7575
Old 06-06-2013, 01:36 AM
1975MudRat's Avatar
1975MudRat
Lol yea, have you got any progress on the interior lately?
Congrats on 500 posts!
Quick Reply: GOOD MORNING!!
