1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
5.4L 4x4 Broke rusted dipstick tube
Old 04-05-2011, 08:04 PM
dillenger1's Avatar
dillenger1
dillenger1 is offline
Got a truck with a rusted dipstick tube in the pan.Ive removed the manifold to do that while im at it.removed the motor mount.ive tried removing with a tap but the tap snapped off in the bottom.Im removing the oilrail or trying to.Is there anything im missing besides the obvious bolts.I smacked it pretty good.Its a plow truck so everythings pretty fused.
Old 04-05-2011, 09:07 PM
twall_SD250's Avatar
twall_SD250
twall_SD250 is offline
i dont have any input for you but let me know how you make out. i have the same problem but my rotted off right above the mounting bracket. i had my buddies shop look at it but he was afraid if he tries getting it off without removing the manifold it might snap off at the oil pan. he told me if it breaks off flush he would have to drop the oil pan and push it out that way. but as we know you can just drop the oil pan without raising the motor up.So you have a $14 part and hundreds in labor.
Old 04-05-2011, 10:14 PM
ganzey's Avatar
ganzey
ganzey is offline
same thing happened to me. when i bought mine it was broken off flush with the engine. a couple of bolts on the oil rail are REALLY hidden, get a mirror to help.
What i did
-remove engine mount
-remove oil filter cooler thing
-did NOT remove exhaust manifold
-threaded a tap into the tube, then heated the **** outta it, grabbed the tap with vise grips, and pounded it out.
while i was at it i notice the lower radiator hose was rubbing on the frame and almost worn through, replaced that
also you will need the oil filter mount gasket
the WORST part, was rocking the engine to the passenger side to remove the oil filter cooler thingy, and pounding out the old one.
overall we spent 7 hours taking it out, 3 to get it all back together. just take your time
Old 04-07-2011, 05:02 AM
dillenger1's Avatar
dillenger1
anyone know what the combination gasket is called for the lower coolant inlet/oil feed return at the parts store?They were baffled when i went up there
Odisvan
05-30-2017 11:44 AM
PeteB4
Modular V10 (6.8l)
11-11-2015 03:23 PM
navistardiesel
12-04-2012 07:20 PM
rv4jesus
6.4L Power Stroke Diesel
03-25-2011 06:45 PM
Jacobjj85
1997 - 2003 F150
05-22-2009 10:21 AM
Quick Reply: 5.4L 4x4 Broke rusted dipstick tube
