99-04 super duty leaf spring lift in 71 f250
#46
It had great penetration on the 1/2" plate I wasn't even at full blast its rated for 1/2" steel in a single pass and 3/8" aluminum I'll have an update with pics soon got my new rear under it and some big honkers 40" tires on it now it looks mean got my bushings today so I just need some 1/4" plate so I can start doing the cummins mounts hoping to find a Dana 60 front and a divorced NP205 t case this weekend. So your trucks to big now Hahaha bigger then you wanted or no?
#48
man thats some serious weld.... bad a$$. and yes way to big for me. i have a goose neck camp trailer to pull.... once i get it a weighed down and move the front shackles to the perfect angle it will be a little lower. enough i can live with it. thats sick i want picks of that monster on 40's should be easy to find your case though. hopefully anyways. ya were pretty close on the builds for sure.... good heads up on the ac pump. wish i could help on the front 60 a 78 79 hp kp goes for about 1200.00 around here. but there is a few on ksl. a local classifides section for ut wy id. dont know what the price jump is for you.` less or more???
#49
#50
Ryan. Are u asking me? If so I will get you a part number. But I ran a 93 dodge cummins 6 inch spring and crazed ran a Ford SD spring Im not sure what the part number is. And I think I may have it wrote down at work I can look tomorrow. I think its a 99 to 04 SD 6 inch a spring. Let me know.
#51
Yea I've always been a skyjacker fan I believe build it once the right way that's what's taking so long I been saving and getting parts little by little the past 2 years and finally I can see some progress I believe I got them for around 500 for the pair of rear leafs ill try finding the paperwork on them when I get a chance see if I can dig up a part number for you
#53
#55
alright now for the big honkers on it it really changes the look of the truck and i actually see progress now but long ways to go the rust on this cab is horrible was real bad when i first got it i replaced the floor pans and cab mounts now i need the door bottoms inside the front doors below the hinge and cab corners so ill be busy for awhile check out these pics that one has a 30'' tall tire sitting behind the rear 40'' shows how high it sits this is under its own weight no jacks
#56
and the rear 14 bolt install like i said it was almost the same leaf perch spread as my dana 60 was 40 1/2'' and this is 43'' i think it's close to bolt in when using the SD leaf mounts like i did it hung the leafs alittle more out then the stock setup noticed this when i sat the SD rear leafs on the stock dana 60 good deal beefy axle sweeet..
#57
