99-04 super duty leaf spring lift in 71 f250
Old 04-27-2011, 12:55 PM
crazed87bronco's Avatar
crazed87bronco
crazed87bronco is offline
Thank you for the info so I will measure the distance from center of eye to eye following the arch then measure from the solid mount hole to the shackle as its flipped as far back as it can go as long as this measurement is longer then the spring measurement it will be fine?
  #32
Old 05-15-2012, 06:58 AM
crazed87bronco
ok its been long overdue for an update in this thread i was going with those SD front hangers and mounting them up front but i made a different front crossmember instead gives alittle more lift then the stock one and in the rear i went with four SD solid leaf mounts and used the shackles so everything bolted up easy truck is at a nice height now alot from stock just need to find some tires
  #33
Old 05-15-2012, 01:51 PM
crazed87bronco
and heres the rear and what i had to deal with check out the old springs snapped in half
  #34
Old 05-15-2012, 01:59 PM
crazed87bronco
  #35
Old 05-15-2012, 02:14 PM
crazed87bronco
i wasnt liking the rear shackle angle once i lowered the truck and its on its own weight so i relocated the rear hangers back farther now they look alright there it is suspension is just about done need to drill the rest of the hanger mounting holes out bolt them solid and just need shocks anybody have some suggestions on what kind of shocks to look into? in the end it was worth it cant wait to drive it and feel the soft ride rear springs
  #36
Old 05-25-2012, 03:38 PM
highntight's Avatar
highntight
highntight is offline
man thing is huge.... looking good, i liked how they turned out. that is a ton of spring lift without blocks. now you just need to get your 40's stuffed under that pig. hows that new welder treatin ya???
  #37
Old 05-25-2012, 10:45 PM
wyoming4x4's Avatar
wyoming4x4
wyoming4x4 is offline
wyoming just checkin in.
lookin good. never enough time to do these projects. workin mine also and gaining ground. rain and snow memorial weekend. slowing things up a little.
  #38
Old 05-25-2012, 11:36 PM
crazed87bronco
How's it been Wyoming your crew cab coming along nice Ayy? Looks like you got a flat bed on in your avatar ill have to see your thread on it should be nice all weekend here in pa saying it maybe hitting 90 out highntight yea it is a lot of leaf like how it turned out almost ready to start welding going today to get a breaker and the last power wire I need to be able to wire it up I have everything else next on list is making motor mounts then add the 79 power steering box and crossover steering going to try today to look at a rear axle and some 40 tires if not Sunday and looking for a Dana 60 now to go under the front
  #39
Old 05-26-2012, 10:00 PM
highntight's Avatar
highntight
good thinkin.... that will be be a good upgrade. i ran the blistiens on my red dodge dont know if they made any huge difference but i liked them all the same.... your moving right along there mr.... did you decide to go to the bushing style mounts then???
  #40
Old 05-26-2012, 11:38 PM
crazed87bronco
Yea I decided to go with the bushing style mounts and around 1/4" plate to tie it all together I got the welder hooked up and just need to dial it all in the couple passes I made weren't to great need to get use to these settings on this welder I still need to figure out what shocks to run any suggestions
  #41
Old 05-27-2012, 07:01 PM
highntight's Avatar
highntight
i ran blistiens shocks on my dodge... little pricey but they worked well. and good deal. what welder did u get.
  #42
Old 05-27-2012, 09:55 PM
crazed87bronco
Got my rear axle today and should be getting them tires tomorrow and putting everything under the truck that's my project until the bushings come I got a little time today to lay some welds getting a feel for the settings now looking good its a miller 252 welded some 1/2" plate today with it I'll have to start researching different shocks
  #43
Old 05-27-2012, 11:29 PM
highntight's Avatar
highntight
wow thats some thick plate, how was the penatration. and i think the cheapest shock on the market would be plenty. there probably no different then the expensive ones...
got my cab on my frame today. pretty excited. its way to damb big though.
  #44
Old 05-29-2012, 01:16 PM
ryanhablitzel's Avatar
ryanhablitzel
ryanhablitzel is offline
What kind of rear springs are those? Pro-comp 2000ish superduty lift springs? How much lift are the spring you are using giving over stock?
  #45
Old 05-29-2012, 09:36 PM
crazed87bronco
The springs are 8" skyjacker 99-04 front and rear leafs my custom front spring mount/ crossmember adds around 1 1/2" extra lift over the stock crossmember and the way I set up the rear hangers using both front solid leaf mounts for the front and rear gives it alittle more height I'd say the springs alone added about 8-10" by themselves I have my stock height wrote down somewhere so I could see how much lift I got in the end but I can't find it I can always measure what I got now and compare it to someone else's stock truck measurement
Quick Reply: 99-04 super duty leaf spring lift in 71 f250
