99-04 super duty leaf spring lift in 71 f250
#31
#32
ok its been long overdue for an update in this thread i was going with those SD front hangers and mounting them up front but i made a different front crossmember instead gives alittle more lift then the stock one and in the rear i went with four SD solid leaf mounts and used the shackles so everything bolted up easy truck is at a nice height now alot from stock just need to find some tires
#35
i wasnt liking the rear shackle angle once i lowered the truck and its on its own weight so i relocated the rear hangers back farther now they look alright there it is suspension is just about done need to drill the rest of the hanger mounting holes out bolt them solid and just need shocks anybody have some suggestions on what kind of shocks to look into? in the end it was worth it cant wait to drive it and feel the soft ride rear springs
#36
#37
#38
How's it been Wyoming your crew cab coming along nice Ayy? Looks like you got a flat bed on in your avatar ill have to see your thread on it should be nice all weekend here in pa saying it maybe hitting 90 out highntight yea it is a lot of leaf like how it turned out almost ready to start welding going today to get a breaker and the last power wire I need to be able to wire it up I have everything else next on list is making motor mounts then add the 79 power steering box and crossover steering going to try today to look at a rear axle and some 40 tires if not Sunday and looking for a Dana 60 now to go under the front
#39
#40
Yea I decided to go with the bushing style mounts and around 1/4" plate to tie it all together I got the welder hooked up and just need to dial it all in the couple passes I made weren't to great need to get use to these settings on this welder I still need to figure out what shocks to run any suggestions
#42
Got my rear axle today and should be getting them tires tomorrow and putting everything under the truck that's my project until the bushings come I got a little time today to lay some welds getting a feel for the settings now looking good its a miller 252 welded some 1/2" plate today with it I'll have to start researching different shocks
#43
#45
The springs are 8" skyjacker 99-04 front and rear leafs my custom front spring mount/ crossmember adds around 1 1/2" extra lift over the stock crossmember and the way I set up the rear hangers using both front solid leaf mounts for the front and rear gives it alittle more height I'd say the springs alone added about 8-10" by themselves I have my stock height wrote down somewhere so I could see how much lift I got in the end but I can't find it I can always measure what I got now and compare it to someone else's stock truck measurement
