Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 03-30-2011, 10:23 AM
scholzee scholzee is offline
Garage is empty, add now
scholzee is starting off with a positive reputation.
2008 Expy front pass axle seal leak & 4x4 pop
Ford dealer replace pass front axle seal (4x4) where half shaft goes into diff housing 1 year ago due to oil leaking out. It is now wet again and the put dte in and said is oil from the new seal design and not diff fluid. Anyone know of TSB's or any info on this. I would also get an ocassional bang with seemed to come from front end when turning and in 4x4 on total snow covered roads, no dry pavement. My tires are less than 1 year old 8,000 miles and the say the diameters are 1 " of causing this, I asked if they checked pressure of tires and they said no. All advice appreciated.
  #2 (permalink)
Old 04-04-2011, 01:56 AM
Pilgrim Pilgrim is offline
Pilgrim is starting off with a positive reputation.
I had same thing on my 2008. Replaced a year ago at 65,000 kms now leaking again. I'd like to replace it myself this time and hope for a better/more permanent fix. Anyone done it or got the service manual describing the procedure? It only took an hour or two at the dealer, but looks like more than that to me.?
Pilgrim
Tags
1977, 1999, 2002, 2003, 4x4, axle, differential, escape, explorer, fix, ford, front, leak, lincoln, navigator, ranger, replacing, seal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
