Battery gauge fluctuates when started...
Hi, I have a 1997 Ford F350, just installed two new batterys and on start up the battery gauge pegs real low and when started it fluctuates from about a 1/4 to 1/2 for about a min, then it stays at about 3/4. Is this normal? it doesnt seem to have any problem starting.
Yes. It's the glow plug relay kicking on and off, not good for the relay but it is normal.
I turn my headlights on and hvac fan on high to cause electrical draw till the GPR shuts off.
The PCM is set to have the relay on up till 14.1 or 14.2 volts, once the charging system reaches that it shuts the GPR off to prevent over-voltage to the GPR. Then, the volts drops and it kicks the GPR on, then the volts rise and shuts it off, then the volts drop and kicks it on......and so on...
Edit:
Seems to be common on '97. Both my '97 do that, but my '95 and '96 do not.
Edit:
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Read this thread, it might answer your question, eventually....
https://www.ford-trucks.com/forums/1...warning-3.html
guisepi
04-29-2019 05:01 AM
Lneidlinger
09-29-2015 05:59 PM
mb5518
1983 - 2012 Ranger & B-Series
09-17-2014 07:12 AM
pomial
1997-2006 Expedition & Navigator
10-20-2013 12:00 PM
Ogriv
13
01-11-2006 08:04 AM
