Air only comes out of defroster
I have seen in the past that the control **** can get stripped.When you THINK you are turning it to a different position,the **** will move,but the shaft in the climate control is actually not moving.
I suggest pulling the **** off,and looking to see if its broken.If it looks ok,and there is no evidence of cracking of the flange....use a needle nose vice grip,and carefully turn the shaft to a different position...Feel for "detents".......Basically "parking" spots as the shaft rotates.Check to see if the air comes out the vents/floor etc.If rotating the shaft fixes the problem,the **** is indeed at fault.If there is no change,I would suspect the climate control assy is defective.
IIGood
01-21-2016 06:12 PM
mappy881
01-04-2016 06:37 AM
tofino
10-13-2014 12:01 PM
