Air only comes out of defroster
Old 03-24-2011, 07:42 AM
The Giant Noodle's Avatar
The Giant Noodle
The Giant Noodle is offline
Well, the air wont come out of any vents except the defroster.
Anyone have any ideas?
Old 03-24-2011, 07:40 PM
n5926g's Avatar
n5926g
n5926g is offline
I have seen in the past that the control **** can get stripped.When you THINK you are turning it to a different position,the **** will move,but the shaft in the climate control is actually not moving.
I suggest pulling the **** off,and looking to see if its broken.If it looks ok,and there is no evidence of cracking of the flange....use a needle nose vice grip,and carefully turn the shaft to a different position...Feel for "detents".......Basically "parking" spots as the shaft rotates.Check to see if the air comes out the vents/floor etc.If rotating the shaft fixes the problem,the **** is indeed at fault.If there is no change,I would suspect the climate control assy is defective.
Old 03-25-2011, 12:36 PM
wahl7s's Avatar
wahl7s
wahl7s is offline
Or it could be vacuum, defrost is the default position if you have a bad line from the engine to the climate control switch assy. that would also cause your problem
Old 03-25-2011, 01:25 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Go to the HVAC section and read the FAQs there. Your problem is covered.
Old 03-25-2011, 05:06 PM
The Giant Noodle
Cool beans man! Thanks
IIGood
01-21-2016 06:12 PM
racin
1997 - 2003 F150
01-14-2016 09:00 PM
mappy881
01-04-2016 06:37 AM
tofino
10-13-2014 12:01 PM
viper29
07-01-2013 07:27 PM
Quick Reply: Air only comes out of defroster
