help i am losing atf oil fast i see no major leaks and no oil in radiator i do have a semi big leak coming out of the t-case front output shaft for the front axle does the t case share oil with the trans? if not where could my oil be going
The transmission and transfer DO NOT share oil. However, it sounds like that may be what you have going on. It sounds like the seal on the rear of the transmission is bad and allowing your trans oil to transfer into your transfer case. Id bet if you pull the fill plug on the transfer case, you will find it is overfull and diluted with transmission oil. That could be the cause of your leak on the front yoke as well. As the transfer case fills with transmission oil, it builds pressure that found its way out. In your case it sounds like it found its way out of the front yoke seal.................
From way back in the old memory bank, I believe a modulator can cause this also. Most likely the seals as mentioned,,,,assuming you don't have a divorced transfer case.
