shimmed FPR last night
I changed my fuel filter and air filter again last night, more so because I was curious than it needed it. I just changed them in December, anyway...I was Kinda chasing a problem in the higher tunes (5,6), in 6 especially when you push the loud pedal past say 1/4 to 1/3 the truck lays down. meaning It actually pulls harder at 1/4 throttle than WFO throttle. I figured I would check the fuel press while I was in there. It was at 43 PSI so i pulled the FPR apart and did the bb trick. the pressure jumped up to just over 70. and it helped quite a bit with the problem but it is still there. Could it be the HPOP dying? I have also noticed that sometimes my injectors change sound during idle. like maybe the high pressure oil comes and goes???
what do you guys think?
also whats the best way to check the high pressure oil? where do I plumb the gauge in?
Sorry for the rambling
John
John
CPL. Chaz
12-19-2012 04:53 PM
kirkharrod
12-10-2011 06:14 PM
sean heim 96 stroker
01-10-2010 09:32 PM
driptorch970
04-28-2009 05:55 PM
