I love my new radiator an electric fan
#61
AKforceten:Can you comment on the quality of the Alumarad radiator application you posted? I am running a desert cooler right now (with A/C) in Phoenix. I'm shopping for a replacement radiator and you can't beat that 209 dollar price tag! If its a good radiator, I would like to give it a go. Thanks, Roy
#63
First let me say sorry for not responding quickly , had some puter problems. as far as the alumarad I did not buy that one but it is the same unit I did buy from 1-800 radiators there all made in china the alumarad is cheaper than 1-800 radiators . I can tell you Roy that the one I got is doing find. I'm also putting one in the bronco also from 1-800 radiators . I bought both radiators before I found that link ! I paid $260 a piece for mine at the shop rate, so the alumarad sounds like a better deal!
#65
Got busy at the junkyard today...
The 3g alt and one fan are from a 96 3.8 T-Bird, the other fan is from a 94 v8 'bird. Looks like I have some wiring to research. Thanks for all the folks who have been participating in this thread, and of course akforceten for starting it! Makes it easy for someone like me to make the leap!
While hunting for the winged beasts, I also found this:
But they wanted $200 for the head alone, and I have no real use for it. Though it WOULD look disturbing strapped to the side of the 2.5L I6 in my 74 Triumph!
#66
Your welcome DrainBramage . Glad this could help you . The only problem I have had with the 3G alt conversion was a couple of bad connections that caused the alt to not charge . The other thing I wanted to add was if your looking for a 3G alt for FE motors I found the 3G off of the 95 mustang 3.8l cars you don't have to clock to fit.
#67
DrainB: I don't know if you are using a V belt for your 3G, but if you you might want to install a dual belt pulley. I tried mine with one v belt and when the fan is going it squeals horribly. With a second belt on it it doesn't make a peep.
Also, you might want to take a look at the Summit Racing radiators. I use one and am happy with it.
#68
When you guys did your fan installs and alternator upgrades, did you scab everything to the battery side post on the starter relay, or is anyone using a buss bar? I already have a headlight upgrade harness with relays, and now I'm getting ready to add the fan, and things are starting to get crowded.
#69
You can always run a small section of 4 gauge wire down from the battery side of the solenoid to a combination distribution/fuse block like used in Car Audio set ups. That way you don't have all the smaller wires trying to be connected to the same spot and you need a fuse on everything anyway.
Just a suggestion.
Just a suggestion.
#70
A double pulley from any ford alt with work. I used one from a 75 alt and put it on my 92 Taurus alt. You may need to put the washer between body and pulley to avoid rubbing. Or get one from j/y.
Cut the belt, shove a long screw driver through the alt, and torque off the nut.
I would take the alt to A.Zone and have it tested prior to install. I pulled two from j/y, tested both, and have a spare for when the one gives up the ghost.
#71
Just a suggestion.
Just a suggestion.
I'll probably do a dummy write-up on this with lots of pics and diagrams when I'm done, though the rabbit hole is getting pretty deep...
#75
No you have to use a solenoid that is made for continuous duty. The one I use I bought from ebay for $12. I guess they are $16 now.
Continuous Duty Solenoid 80AMP 12V | eBay
As far as the high speed goes I think that depends on where you live. If I didn't have it wired to kick on with the A/C I'd wire it up with just a manual switch just to cut it on if I needed it. Never hurts to have a higher speed available.
