Auto Transmission Shifting Issues
#31
both times it happened to me it was natural to instantly lift my foot off the throttle, it was my natural reaction.
someone needs to get chris brewer back and ask him whats going on. its strange that its effecting both gas and diesel engines. so what I am wondering what is the dealer going to say if when you tell them all of us on here have seen the issue and all of us can't be lying.
I personally haven't been too worried about it because I have a 100k warranty and will probably trade off trucks then or soon after.
#32
#33
I had this happen for the first time Monday. I drove roughly 70 miles then parked at my customers for almost 2 hours. When I hit the parking lot I remote started my truck so it ran for about 60 seconds before I hopped in. I was in a very large school parking lot so I rolled out very slowly (probably 400 yards).
When I pulled out from the parking lot to the very busy 2 lane hwy my truck stalled, rpm's shot up and I had to back off the gas to re-engage the transmission.
This issue has been added to the very long list of warranty work my truck goes in for on Friday.
#34
#38
#39
#40
I should not have opened my mouth about it not occuring more than once since the additional TCM/PCM flash.
It did it once today driving around town for lunch making this the second time since the December flash.
However, today's event was similar to Byram's except involving gears 2 shifting to 3. It recovered on it's own (doesn't normally self recover) after jumping to 3k RPMs while shifting from 2 to 3. The other times I had to slow down to force a downshift then continue (as if nothing happened).
T/H mode was off (normal driving).
I wasn't flooring it.
#41
It does address shifting issues and it is an improvement but it doesn't resolve this issue.
BTW, I have figured out how to completely avoid this on my truck. I just wait until the trans temps reach about 120 before I give it anything more than very light throttle in 2nd gear. I can floor it in 1st or 3rd, but 2nd needs to be babied. The biggest trigger seems to be applying throttle while coasting. I don't do that anymore, either. At least not until the trans is warm.
Just like the throttle lag issue... I have adjusted my driving style to accommodate this one. I never have throttle lag, and now I never have the slippage issue. Hope that helps someone.
#42
I have the same weird shift patterns that are not right - as well as the trans flare up that others are having too. It is wide spread. My best friend has 4 6.7's in his work fleet, every truck does it. Ford knows.
Question is, how the heck did Ford go from such a bullet proof 5 speed that was never in the wrong gear, rarely ever broke, took tons of hp and never complained, and was always composed?
The shift pattern/seqeunce seems designed by a grade schooler. Don't get me wrong, I'm a Ford diehard, but of all my Super Duties ,this has been the most troublesome for me. Cheers.
#43
If I recall correctly, the wording in the TSB specifically said that it was intended to address this issue. That's where I got the term "long soak" from. There's no possible way that Ford can claim they don't know about it. If your dealer is saying that, they need a couple smacks with a cluebat.
#44
Honestly, I've experienced this many times but it has never been dangerous or made me worry. The transmission is under warranty for a very long time. This issue didn't show up for me until I had about 10k on the truck... I'm guessing that it will take a bit more time before Ford has a comprehensive fix for all build dates.
