Is brake combination/metering valve repairable?
Hello, everyone. My '91 Aero XL as developed a brake fluid leak on the back side of the combination/metering valve located just below the master cylinder. The leak is coming from the rear of the valve...see arrow in pic. Is there a way to repair this problem, like replacing an O-ring, or do I need a new/salvaged unit to fix the leak?
Thanks for any info on this part.
From what I've been able to find out, the part isn't necessarily repairable.
Raybestos makes one and calls it an ABS modulator valve. Amazon has it for around $90, but takes 2-5 weeks to ship. HA!
I might have to go to a u pull it yard, in that case. The local Ford dealer told me the part was no longer available.
https://www.ford-trucks.com/forums/2...alve-leak.html
https://www.ford-trucks.com/forums/4...ion-valve.html
More Information for RAYBESTOS ABS570030
Amazon.com: Raybestos ABS570031 Anti-Lock Brake System Modulator: Automotive
that's the RABS solenoid valve. part of the rear axle antilock brakes system on the Aero.
is it the rear line leaking or the plug on the rear?
going to have to pull and look at it. line=make take a new flared end.
RockAuto our site sponsor has them
BENDIX Part # 40053
[Flag indicates this part fits vehicles manufactured for the US Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide.] [Flag indicates this part fits vehicles manufactured for the Canadian Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide.] New Abs Modulator [Wholesaler Closeout -- 30 Day Warranty] (Only 1 Remaining)
$78.99 $0.00 $78.99
and they carry the Rabestos unit, more money
BENDIX Part # 40053
$78.99 $0.00 $78.99
Thanks for your feedback. If I find I can stop the leak myself, I'll post the process here.
