1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
OEM Skid Plates Installation
Old 03-11-2011, 08:19 AM
bives's Avatar
bives
bives is offline
I don't have the FX4 package but oredred the OEM skid plates and installed myself. The components came with no instructions, and I couldn't find any support online. The transfer case plate was self explanatory and fairly easy. The gas tank plate was more challenging. I hope my advice will help save you some time.
My '11 F-250 had an existing fuel tank gaurd (plastic) that mounted to the frame along the outer edge of the tank. The OEM skid plate comes with this same plastic gaurd mounted to the plate.
1) Remove the existing plastic gaurd from the frame (3 nuts and 4 bolts total). I re-used these fasteners. All fasteners are 13mm.
2) Skid plate package comes with 2 support brackets that fasten to the under body of your truck. Under body structure has pre-existing holes that accept the clip-nuts that Ford is so famous for (no drilling required for entire project).
The longer bracket (with 90 degree top mounting portion) mounts near the aft portion of the fuel tank. Pre existing holes in the under body indicate where to mount the bracket.
The shorter front bracket mounts to the under body where there are a couple different alignment options of holes pre existing on the under body. Align the front bracket with the skid plate mounting holes (3 total) and choose the best under body mounting location.
3) The biggest hang-up I had with this relatively easy project was that I didn't know the pre-existing plastic gaurd has to come out first. Once I figured this out, everything else made sense. I ordered the skid plates and associated hardware from my dealer for about $750. Good Luck.
Old 03-11-2011, 01:03 PM
BigPigDaddy's Avatar
BigPigDaddy
BigPigDaddy is offline
Nice first post, can you add some pics?
Welcome to FTE!!
Old 03-11-2011, 07:46 PM
V10ZILLA's Avatar
V10ZILLA
V10ZILLA is offline
Lets see some pictures..before and after.
Old 03-25-2011, 07:00 AM
Scorpion2's Avatar
Scorpion2
Scorpion2 is offline
What are the part numbers? I would love to see some pics also.
Old 05-17-2011, 04:29 PM
Sportscraft's Avatar
Sportscraft
Sportscraft is offline
So is there only 2 on the 2011's. How much were they if you don't mind me asking?
Old 05-17-2011, 07:36 PM
jc8825's Avatar
jc8825
jc8825 is offline
There has only ever been two. My 02 with FX4 has just the two; one on the transfer case, one on the fuel tank.
Old 05-17-2011, 07:53 PM
IslandBlueV10's Avatar
IslandBlueV10
IslandBlueV10 is offline
Hello, is there a source for some aftermarket skid plates? Something cheaper then the OEM.
Thanks
Old 05-17-2011, 08:06 PM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
For the 2011 F250:
4) Fuel Tank Skid Plate - $299.67
3) Transfer Case Skid Plate - $29.38
Silver State Ford Parts (Formerly DIRECTFORDPARTS.COM)Genuine Ford Truck Parts Lincoln Mercury Parts OEM Ford Parts and Accessories
Old 05-18-2011, 11:46 AM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
$750 is a rip off! every 4x4 should get them skid plates regardless. Whats the factory option price like 100 bucks or something, stupid. But at least you have them now like it should have from the beginning
Old 10-11-2011, 03:33 PM
jaypsullivan's Avatar
jaypsullivan
jaypsullivan is offline
Skid Plate Parts
2011 F250 4x4 6.7L Short Bed
Parts list for skid plates
Gas Tank Skid Plate
9K036 SKID PLATE, (BC3Z9K036C), LIST: $401.30, COST: $222.18
9046B BRACKET (BC3Z9046B), LIST: $31.36, COST: $17.36
9046D BRACKET (BC3Z9046C), LIST: $46.60. COST: $25.80
2@ HB1 BOLT, (W506424S439), LIST: $1.00, COST: $0.59 EA.
2@ HN2 NUT, (W705158S439), LIST: $4.00, COST: $2.36 EA.
6@ M8 nuts, flat washers, lock washers from local hardware store for the 2 brackets.
7E036 SKID PLATE, (BC3Z7E063A), LIST: $35.55, COST: $31.41
4@ HN1 NUT, (6C3Z17F790AA), LIST: $8.98, COST: $6.35 EA.
4@ HB2 BOLT, (W712977S439), LIST: $2.00, COST: $1.18 EA.
You can substitute your own nuts and bolts for the transfer case, they
are nothing special.
Old 01-07-2012, 09:44 AM
Davegyo's Avatar
Davegyo
Davegyo is offline
Thanks alot for the part numbers the local ford parts guy i think was too lazy to look up all the parts and kept making excuses.
Old 01-07-2012, 10:07 AM
79CEEJAY's Avatar
79CEEJAY
79CEEJAY is offline
Sounds like you did it right. The fuel tank is a pain. I recently replaced the foot on my pick up tube in my tank and it is certainly a wrestling act.
Old 04-12-2013, 01:55 PM
my_crib_too's Avatar
my_crib_too
my_crib_too is offline
Received 1,183 Likes on 364 Posts
Anyone else ever add skid plates to their trucks?
Old 04-12-2013, 02:51 PM
SuperDutyScaler
like i said earlier EVERY 4x4 should have them stock, especially since you can order them seperate IF you order the truck for a mere 100 dollar's!!!!!
Old 04-12-2013, 02:53 PM
SuperDutyScaler
my dads 2000 F350 Lariat! didnt have them either. We went to a local junk yard and got his for 75 dollars two years ago
Quick Reply: OEM Skid Plates Installation
