6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
New PCM Recal. 11B23
Old 03-10-2011, 05:34 PM
cheezit's Avatar
cheezit
cheezit is offline
I drove a truck the other day and the message center was lit up with cleaning filter message.
  #47
Old 03-10-2011, 06:47 PM
senix's Avatar
senix
senix is online now
Received 1,416 Likes on 1,011 Posts
that is good news as that is the only way I would do this update myself. Especially considering mine runs perfect the way it is.
Still thinking I might just pass it up.
  #48
Old 03-10-2011, 06:57 PM
jimd1050's Avatar
jimd1050
jimd1050 is offline
Worry later? IT IS LATER!
Timing SUCKS!
I'm really gonna test this new flash - I was 1/2 mile from work this morning and it went into Regen. I have to work - I'm not driving another 14 miles or so because the truck needs a Regen! I left work tonight expecting the thing to go into Regen to re-start the canceled morning Regen. Nothing for the entire 40 mile commute... I put my right directional on to turn into my driveway at 6:00 PM and... Yep, you guessed it, "Cleaning F'n Exhaust Filter"! I stormed up the driveway and shut the S.O.B. OFF!
Let's see what happens in the morning when I remote start it and let it idle for 15 or 20 minutes in the driveway warming up? If I get a Wrench Error or go into Limp Mode, I'm going to drive it through the front window of my Dealership... watch the National News tomorrow night. "Massachusetts Man goes Berzerk at local Ford Dealer!"
That would be me!
  #49
Old 03-10-2011, 07:23 PM
senix's Avatar
senix
senix is online now
Jim,
That is exactly what I would of done! Bet you get the mandatory drive to clean message next...but hopefully it comes on as soon as you hit about 150 deg.
  #50
Old 03-10-2011, 07:56 PM
Tom's Avatar
Tom
Tom is online now
That would be me!
It'd take a lot more than that to plug your DPF.
My truck has a similar DPF system to what's on the 6.4L engine, and I never worry much about it. I've shut it off numerous times just after regen with no issues, it really takes a lot to plug these units as long as everything is running right.
Relax and drive the truck, it'll be fine.
  #51
Old 03-10-2011, 08:32 PM
caprang's Avatar
caprang
caprang is offline
ISnt it bad to shut the engine off when the egt's are real high from a recent regen? I always let mine idle a few minutes to cool down with or without a recent regen.
  #52
Old 03-10-2011, 09:08 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
I just drive mine, and ignore the regen. That's why the 'drive to clean exhaust filter' message.
The engineers had to know this stuff would happen, and you can't kill the truck for one stop.
Sam
  #53
Old 03-11-2011, 05:13 AM
senix's Avatar
senix
senix is online now
By the time I pull in the driveway I am at idle anyway. So I put mine in park and let it run a minute or so to cool down the exhaust a little and make sure all that fuel isn't just sitting in the cylinders.
  #54
Old 03-11-2011, 06:25 AM
jimd1050's Avatar
jimd1050
jimd1050 is offline
Completed this morning...
Warmed up in the driveway for about 20 minutes this morning - at three miles after leaving the house, it went into Regen. Regen completed at approximately 15 miles - damned, I was so looking forward to being on the NEWS tonight!
  #55
Old 03-11-2011, 06:35 AM
senix's Avatar
senix
senix is online now
Well when you get that 6-gun it will help to extend those intervals...
  #56
Old 03-11-2011, 02:14 PM
Eric326's Avatar
Eric326
Eric326 is offline
Did you "cleaning exhaust" message stay lit the entire time?
  #57
Old 03-11-2011, 04:18 PM
jimnv's Avatar
jimnv
jimnv is offline
Took my 08 in for a fuel filter replacement just today
Service manager said "...and oh by the way, we initiated a recall that was put out last week or so". He explained to me what it did and why. I expect its going to be something the dealership is "mandated" to do whether we wanted it or not.
I'm still at work so I am going to be watching the dash very carefully plus the performance.
  #58
Old 03-11-2011, 07:25 PM
Gearitis's Avatar
Gearitis
Gearitis is offline
Yep! Took mine in today for a check on the black pipes (did a 900 mile tow with my 5er and came back with more black than I had ever seen) and the service manager said "that while its in here" we are required to do the "new pcm adjustment". My question was, "what is the positives and negatives"? His answer was that I would get better warning of malfunctions and longer intervals between regens, better notification of regen process. The only downside that he was informed was the time it took to do the flash. My other question was "can we go back to the former pcm revision, that is in case it does not perform as well as it does now. He said it is not a good idea to go back but can be done.
I guess we will see.
  #59
Old 03-11-2011, 07:28 PM
senix's Avatar
senix
senix is online now
How far apart we your regens?
  #60
Old 03-12-2011, 07:47 AM
Gearitis's Avatar
Gearitis
Gearitis is offline
90-100 miles and not more. With regens that close together, still averaged 10.4 mpg. Headwind of 30 coming back, impressed the milage was not worse. Will post back with the results on Tuesday or so.
Quick Reply: New PCM Recal. 11B23
