tight steering
Old 03-05-2011, 05:01 PM
compsec's Avatar
compsec
compsec is offline
tight steering
On my 2004 s-cab the steering is starting go 'notchy' any eperience of this and the solution ?
I have considered, tight upper or lower ball joints, pump, rack or even a sticking rear diff, but not carried out any checks yet except oil level
Old 03-05-2011, 08:45 PM
Millzy's Avatar
Millzy
Millzy is offline
There is a 13 mm pinch bolt on the steering shaft at the steer rack. Remove the bolt and slide the shaft off of the rack. You should be able to check the U joints in the steering shaft now. I think you will find a stiff joint in the shaft.
Old 03-15-2011, 04:00 PM
jr105's Avatar
jr105
jr105 is offline
Did you ever find the cause of this condition? I just drove my truck today after it sat for 2-3 weeks and it is doing the same thing. I was thinking it's probably one of the knuckles hanging up after all the salt and sand this winter, but I was curious what you found
Old 03-15-2011, 04:19 PM
compsec's Avatar
compsec
compsec is offline
Yep sure did, there are 2 joints in the shaft from the vehicle bulkhead down to the steering rack as was suggested on this thread, I just sprayed both of them in WD40 and problem solved.
Old 03-17-2011, 10:16 AM
jr105's Avatar
jr105
jr105 is offline
Thanks compsec. A couple of applications of PB Blaster and all is well.
poppajim
1999 to 2016 Super Duty
09-22-2016 08:02 PM
Dr. Johnson
01-06-2012 09:43 PM
Texas Outlaw
12-22-2010 01:21 PM
bronkntrukholik
11-11-2009 10:15 PM
Quick Reply: tight steering
