Turbo 3 valve V10
#47
#49
#50
Let's get some driving impressions, part throttle power, does it feel stronger? Does it accelerate with less throttle than before? How does it do coming up to hills unloaded? I image that it would build a little boost as the engine load increases, and hold speed and rpm right on up the hill.
#51
i dont want to be ignorant to your project. creativity leads to great innovations. but is there any reason why you just didnt go with a 7.3 for your towing needs? i have had a 2 valve 5.4, 3 valve 5.4 and a 2 valve 6.8, none of these trucks could hold anything to my 7.3, especially since all of my mods now. again not trying to down you, just wondering, thats all...thanks
#55
#56
So here's a question, a gas truck and a diesel truck, both have same peak hp, the diesel will obviously have alot more torque, but which truck would be quicker/faster? Both unloaded and loads? If memory serves, it seems that the tow tests by the Mag's, the diesels are quicker up the hill, but the gassers are going faster at the same point on the hill.
I guess, the question would be, this truck makes a little over 450hp, and about 600 ft/lbs. Would it be quicker and/or faster than a diesel with 450hp and 900ish ft/lbs?
#57
I havent driven it enough to check mpg. Just normal driving it should not be affected, but its hard to keep your foot out of it...
Pictures!
Pictures by adgranley - Photobucket
I still need to do some final touches. Like, a protective cover for the turbo assy. Right now its in front of the passenger rear tire, that and make a rain cover for my air cleaner. We cut a hole in the box in the front right corner for the air cleaner.
#58
As far as why I did this instead of a diesel? Well, my truck is paid for and has 49k miles on it. I bought it new and know its history. For a brief moment I thought about trading it for a duramax with 100k on it, similar truck, crew cab 3/4 ton but after driving it a day I couldnt do it. It was a very nice truck but they are not the truck the super duties are. There is allot more "wiggle" feeling in the frames when going over bumps, they dont drive for crap, less room in the cab, seats dont go back far enough for me... bla bla bla I like my Ford. As far as going back to the ol 7.3... I have nothing against them but I like it when I twist the key at 10 below zero after the truck sitting for a month and having it fire off whenever I need it. Considering I dont rack up the miles on this truck the diesel just didnt pay out for me when you consider maintenance costs and such. I know I only have 49k miles on it but the only time I open my hood is to check my oil, and change my oil. Which is only 8 quarts and a filter. And now that diesel is .50 a gallon more than gas, its really a toss up when it comes to mileage.
On the drag strip comparo... Lots of variables there to consider, gassers tend to be faster but sometimes not quicker meaning they generally have more horsepower and less torque, that and a much broader rpm band. Idle to 5k rpm vrs idle to 3500 rpm. That and I really dont care what my 7500 lb truck does in a quarter mile. Thats what my mustangs are for. However, I'm more into autocross.
I'm not going to start a gas vrs diesel fight, its just the gas works better for my needs and wants.
#59
That's awesome to hear! Do you know what the specs are on the 6.7 cumins turbo? They are vet are they not? It would be interesting to know the compressor and turbine specs to see what else might match it.
What rpm where you at on the hill in overdrive? Being that turbos are load sensitive, I would imagine that it could build boost even lower in the rpm band in the higher gears than it would on a dyno.
Keep the updates coming as you drive it more!
