truck wont run...correctly...
so my behemoth will idle fine, but i get on the gas and it'll stall out..ill get a video of it tomorrow after i re-hook up my tech..so i can get a video of the RPM's
if i can keep it from stalling out, it only revs up to about 3500RPM and stays there..it wont willingly go higher unless i floor the gas where it'll rev up to who knows what..and i don't know how to adjust my holly 4 barrel to make the fuel/air mix richer..i think im running too lean...
I know that there's supposedly an idle mixture screw towards the front passenger side of the base of the carb, and from what I understand it may be plugged and need drilled out if it's never been messed with. these scans are all I have on the 4180, hopefully they help some. parts #'s 83,84, and 85 in the exploded view show the idle mixture screw.
