Can E85 damage engine if never used in past?
Hi all,
I have a '99 flex fuel Ranger 3 liter V6. I don't think it has EVER had E85 in it. If I start using it could it cause trouble?
I know the EFI system has to do some kind of adjusting to work with E85 and since it has never had to adjust to that in all these years I wonder if there could be a problem.
Thanks!
Thanks!
I am completely talking out my butt here, but I dont see how it would be any different than a truck that had its computer reset.
Also, I may totally be wrong, but think I remember there being a sensor that is used to tell whats going through the truck. Sort of like a knock sensor or MAF that if not working properly can cause some problems.
I am sure someone with more knowledge will come by soon.
Welcome aboard!
Welcome aboard!
Hi all,
Thanks!
Thanks!
Hi all,
Thanks!
Thanks!
Seeing as how you have a flex fuel engine, it's ok to use E85, as it's gaskets, seals & fuel system materials are designed to be compatable with it. BUT make sure you use a quality product & go to a station that sells a lot of it, so your more likely to get a clean, quality made & fresh product.
Ethanol has an affinity for moisture, so the high ethanol content of E85 will have been looking for & absorbing any moisture along the transport & storage route, before you pump it, so you'll want to be plenty persnickety about whose brand you choose & where you buy it.
As has been said, it'll also clean up your fuel system too, so make sure your fuel filter scheduled maintenance change out is up to date.
There is a big difference in energy density between 87 octane, E10 & E85, with the higher content ethanol fuel being less energy dense, so we'll need to burn more of it to go the same distance. As has been said, your flex fuel vehicle has a fuel sensor, to alert the computer whats being used & the computer then makes fuel trim & timing adjustments to make the best use of what it has to work with.
Money wise, unless the E85 is a lot less expensive to buy where you live, you'll be lucky to break even on cost per mile.
More thoughts for pondering, good luck on your test, let us know how it goes.
About your fuel filter, on flexfuel Rangers, there are two types of fuel filters; one is for regular and E85 and one is for regular only. Ask me how I know this.
Either way, if you have never run E85 and have never changed or had a shop change the fuel filter you should be fine....otherwise, I'd check it out to be sure first.
I did change the filter a couple years ago and I remember the guy at NAPA needed to know it was flex fuel in order to give me the right one.
Right now it's about .85/gallon less here in Sacramento. That was my main motivation, but if the mileage sucks that up I guess there's no point. Maybe I'll just put in a couple gallons now and then to keep the system clean... hope it won't break loose some crud and plug an injector!!
That's exactly my concern... the truck runs fine now, so why risk it???
For what it's worth, I bought my '02 in 2006 from CarMax when it had 27k on it; since then I have changed the fuel filter only once, in 2007, and have run E85 three times in 2008; now it has 96k on it and runs fine. The only issue I experienced was that I averaged about 14mpg with the E85...it didn't knock anything loose or anything like that but the mileage definitely sucked. (One thing I do is run a bottle of fuel injector cleaner about every 5 or 6 tanks of gas)
So, I only use gas now and because of that I run fuel injector cleaner every 5 or 6 tanks.
