led interior lights
Old 08-29-2012, 08:48 PM
TXtinct's Avatar
TXtinct
TXtinct is offline
You'll shoot your eye out
Great, thanks for the info.
  #47
Old 08-30-2012, 03:05 AM
ford_model'a''s Avatar
ford_model'a'
ford_model'a' is offline
Curt's05, where did you procure those two small bright spot LEDs you installed for map lights in the overhead console? They look very clean and effective. I have tried replacing the original incandescent bulb with different LEDs with less than satisfactory results in the front seat reflector dome sockets. I checked out that Menard's site and found mostly household lamps. Do you have part numbers maybe?
  #48
Old 08-30-2012, 05:26 AM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
unicornstainless.com, a friend was looking for this type to install into his deck railing and found these. We installed 16 at 3 ft spacing to give the deck/railing mood lighting.
  #49
Old 08-30-2012, 06:39 AM
Treker58's Avatar
Treker58
Treker58 is offline
Not sure if these are the same but Walmart Automotive has them around us
**** EVO Formance LED Multiusos, White: Automotive : Walmart.com
  #50
Old 08-30-2012, 07:43 AM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
The ones i have are called micro star about the same price, those are close & black would look good!
  #51
Old 09-05-2012, 10:14 PM
goodmatt2002's Avatar
goodmatt2002
goodmatt2002 is offline
TXtinct thanks for such a quick job of sending me the led lights! I installed them when I got home from work tonight and WOW what a diference.
  #52
Old 09-06-2012, 10:36 AM
TXtinct's Avatar
TXtinct
TXtinct is offline
No problem, glad you like 'em. Post up a pic if you get a chance.
  #53
Old 09-06-2012, 10:37 AM
TXtinct's Avatar
TXtinct
TXtinct is offline
Originally Posted by Curt's05
Cheap leds at menards, glued to the hood liner, hooked into the hood switch for over a year now. It helps a lot at night, as we are always looking under the hood!
Where did you splice into the hood light for power. I did mine and I don't think it's turning off when the hood goes down.
  #54
Old 09-06-2012, 08:07 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
Pushed the leads into the bulbs socket of the hood light switch
  #55
Old 09-07-2012, 11:53 AM
TXtinct's Avatar
TXtinct
TXtinct is offline
Well there you go, that's probably the problem. Thanks again.
  #56
Old 09-07-2012, 12:03 PM
TXtinct's Avatar
TXtinct
TXtinct is offline
Thought I'd share the project I worked on last weekend since there are some LED lovers in here.
I did the under hood light like Curt's05 showed us.
I added some under door lights as well. These really light up the ground at night.
  #57
Old 09-08-2012, 12:43 PM
ATG_Tuning's Avatar
ATG_Tuning
ATG_Tuning is offline
TXtinct....looks like you sold someone on here everything needed to swap out all the lights in the car....have enough sitting around to send me a little package also!? Also, where did you get the strip for under the map pocket...is it just a cheap autozone item or is it from somewhere else? Looks great.
  #58
Old 09-08-2012, 01:54 PM
TXtinct's Avatar
TXtinct
TXtinct is offline
I'm on the road right now but I will PM you when I get back. I have plenty.
  #59
Old 09-08-2012, 02:01 PM
ATG_Tuning's Avatar
ATG_Tuning
thats awesome.... i appreciate the help. There are so many different styles/brands/makers out there it is hard to decide what is a quality piece and what is garbage.
  #60
Old 09-08-2012, 06:40 PM
TXtinct's Avatar
TXtinct
TXtinct is offline
Hey ATG_Tuning, you need to enable your Private Messaging so I can send you some info my friend. Under User Control Panel you will be able to take care of that.
Quick Reply: led interior lights
