Help! Alternator or voltage regulator?
Old 03-01-2011, 10:44 AM
radmacks's Avatar
radmacks
radmacks is offline
2002 Excursion 7.3, Getting 12 volts at fast idle 1100 rpm no load. 8 volts under full load. Gages and radio etc cutting in and out. My question is, is there a voltage regulator i should check first or should i start with the alternator ? Not sure if there is even a voltage regulator what should I check/test first, New to me truck in Nov this year so not to sure how old the alternator is.
Old 03-01-2011, 10:56 AM
lee231's Avatar
lee231
lee231 is offline
Voltage regulator is inside the alternator, just take it off and a local parts store test it for you. You can drive it to the store and most will test it on the vehicle for you. Lee
Old 03-01-2011, 10:59 AM
clintbonnie's Avatar
clintbonnie
clintbonnie is offline
I think your alternator is toast..but check the wiring and plug that come out of the alternator.. maybe just loose.
Old 03-01-2011, 11:06 AM
radmacks's Avatar
radmacks
radmacks is offline
Thanks for the tips Checked all connections everything looks tight and clean, I'm going to take it off and take it in for a test
Old 03-01-2011, 11:18 AM
cj45lc's Avatar
cj45lc
cj45lc is online now
If you can find a starter/alt shop they can replace reg/rectifier, just had mine done $98
Old 03-01-2011, 11:22 AM
radmacks's Avatar
radmacks
radmacks is offline
That's a good point thanks, Maybe i'll call them and find out. So far I'm looking at $300.00 for a replacment.
Old 03-01-2011, 11:33 AM
cj45lc's Avatar
cj45lc
You'll be way ahead in the long run, the guy that repaired mine said it was nothing special. Gave it to him at noon one day & picked it up the next morning.
Old 03-01-2011, 11:34 AM
clintbonnie
www.PartsGuyEd.com has OEM alternator for $169.42 plus shipping..
Alternator, f350, 7.3l diesel, 110 amp, single alternator
99-01 $235.30 $60.00 (core) Your Price $169.42
Old 03-01-2011, 11:40 AM
cj45lc's Avatar
cj45lc
Originally Posted by clintbonnie
www.partsguyed.com has OEM alternator for $169.42 plus shipping..
I wonder who does the reman. on those
Old 03-01-2011, 12:11 PM
radmacks's Avatar
radmacks
radmacks is offline
Got a quote for $165 just to change the rectifier and $198 for rebuild, Parts source with discount is $160.88 three year warranty. Looks like parts source it is, Wish I lived near a Autozone. $128.00 LOL
Old 03-01-2011, 06:45 PM
cj45lc's Avatar
cj45lc
Wow...I hope the guy that gave you the quote gave you a kiss, as in foreplay because he sure was trying to get to the good part.
Old 03-01-2011, 07:20 PM
radmacks's Avatar
radmacks
radmacks is offline
I have never had any luck with the re builder here, he quoted me $200 to rebuild my convertible pump I said there only $199 new. Parts Source here in Canada was $180 after tax and core and it was a 110 Amp Motorcraft. Its all fixed and running again and a very easy job luckily as it was -34C here today. Its funny at first I thought it was electrical gremlins as the truck was still running fine other then electrical. Then I remembered Diesels don't have spark plugs lol. I checked the voltage using Torque for android and had 10 volts with all the accessory's off and figured it was safe to limp home.
Question though for future incidents does the HPOP use power ? and if it does then i guess it would be bad to drive home with no power?
Old 03-01-2011, 08:38 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Glad all you needed was an alternator.
Just because it doesn't have sparkplugs doesn't mean it can run without power. PCM, IDM, Sensors, fuel pump aren't going to work without power.
artieb
Escape & Escape Hybrid
01-25-2016 10:59 AM
lauraj
11-10-2015 07:28 PM
Smirks90
13
11-01-2014 05:11 PM
zeus77
1999 to 2016 Super Duty
06-08-2012 03:28 PM
Quick Reply: Help! Alternator or voltage regulator?
