400 cid Fuel Mileage
Old 02-28-2011, 08:34 PM
hunterlee15's Avatar
hunterlee15
hunterlee15 is offline
I'm looking at a 1979 F150 4x4 for my 16 year old. It only has 47,000 original miles on it, but it has a 400 with a 4 spd and I am concerned about the mileage it will get. Would swapping the 400 for a 351 or 302 improve the mileage noticably? Or is there maybe another route to go to improve the mileage, i.e. changing trans? When he's older and can afford the gas, we could always go back to the 400. Thanks for any suggestions.
Old 02-28-2011, 08:37 PM
Vinford's Avatar
Vinford
Vinford is offline
If your worried about fuel your buying the wrong type of vehicle for him.
Old 02-28-2011, 08:55 PM
JustBlaze's Avatar
JustBlaze
JustBlaze is offline
I doubt a 302 or 351 would get better mileage in a 4x4. They would have to work harder. The 400 makes a ton of torque down low and that helps with mileage.
Old 02-28-2011, 09:58 PM
cowboywanabe's Avatar
cowboywanabe
cowboywanabe is offline
Posting Legend
My truck has the 400, it was rebuilt, has about 12,000 miles on it... The best I've gotten was 12mpg on a 200 mile trip across Nebraska. No wind, it was summer time, and I stayed under 65mph. The engine is stock except for the edlebrock intake and 4bbl.
I don't keep track of the mpg's when I'm running around town.
Old 03-01-2011, 07:49 AM
Fat&Bald's Avatar
Fat&Bald
Fat&Bald is offline
My 78 F250 (400\4 speed\Edelbrock intake with Holley 4 barrel\4.10 gears) typically got 10-12 mpg around town or highway, with a load or without. The gas mileage dropped off at speeds higher than 60 or so. You will not likely improve the gas mileage by going to a 302 or swapping the trans to an AT.
I've recently swapped to a Q-jet on a rebuilt 400 with a different cam so I'm hoping for an increase in mpg but even then it may only be a couple mpg.
A high school kid with little income is going to have a hard time keeping that truck on the road.
Old 03-01-2011, 08:06 AM
MikePacey's Avatar
MikePacey
MikePacey is offline
If you put on a straight up timing set and headers with dual exhaust you'll see a mileage increase not sure by how much. What is your rear gear ratio? 3.54? 4.10? If you run a 4.10 run a big tire to lower the overall gear ratio. Or just swap to the 3.54. The more volumetric effiancy your engine gets the better mileage you will get since your engine is working less. swapping cams to one a little bit bigger then the stock one will help. Running like a little 600 cfm 4bbl vaccum secondary carb will help because you can adjust it better. And the vaccum secondary helps because you will run on the two front barrels till you stomp on the throttle. Lighten the truck up. For every 100 pounds you lose you gain 2% in fuel mileage.
Old 03-01-2011, 08:12 AM
ibleedblue1385's Avatar
ibleedblue1385
ibleedblue1385 is offline
What he said. Assuming the engine runs smooth and clean you should be in the 10-12 mpg range.
Old 03-01-2011, 11:37 AM
hunterlee15
Thanks for all the feedback. Some pretty good food for thought. May leave this truck in the garage for a build myself later on!
Old 04-15-2016, 06:54 PM
30odd6's Avatar
30odd6
30odd6 is offline
unbelievable milage for a 400
I know this was years ago, but I just signed up. as for fuel mileage with a 400, I was just amazed at what I made mine get. I have a 78 f150 4x4 with granny gear powered by a true stock 400 with a 2150 2bbl. i decided to see what I could squeeze out for mileage with the motor running at optimal power (never go lean! I know that robs hp and mileage, not to mention harming the engine). I have opened the exhaust to 2-1/2" with mufflers as far back as possible, did away with most of the vacuum, set timing to around 12btdc initiallly and checked total timing to 34btdc and adjusted vacuum advance with the 1/8" allen inside to coincide with how fast it gets there ( I ended up with 15btdc at idle), carb overhaul and tuned by vacuum (which is about 21psi, I went back and forth with timing and vacuum). anyhow, I ended up getting 17.987 mpg!!!! and still have the horsepower to not use a chainsaw....just hook the chain to a tree and pull the whole f$#ker out!!! lol . one added thing, because it was a test, I know these engines loved leaded gas, so I used 91octane and added a bottle of 104+. so, if everyone keeps saying that you can ony get 8-10mpg, they havenet worked hard enough to get the 18mpg....even without the 10-4+, I will get over 15mpg....I LOVE MY TRUCK !!!!!
Old 04-09-2019, 12:00 PM
TCR's Avatar
TCR
TCR is offline
Thats amazing
Old 04-09-2019, 09:11 PM
hivoltj's Avatar
hivoltj
hivoltj is offline
I had a stock '78 rcsb 4x4 with a 400 and 4 speed in high school and college. It got 12 mpg in town and 14 on the highway.
Old 04-09-2019, 09:43 PM
78Hayride's Avatar
78Hayride
78Hayride is offline
Flat out wrong vehicle if you are concerned about mileage. My 78(stock 4002v) is a weekend driver. My daily driver is a Tacoma getting 19mpg. Recently rented a Nissan Sentra for a cross country drive. We average 47-49 mpg. Wow was that a change, I thought the gas gauge was broken at first.
Old 04-09-2019, 10:20 PM
caravaggio2000's Avatar
caravaggio2000
caravaggio2000 is offline
I think you should consider how much he'd actually be driving it. Will he be driving it to school every day? Will he be driving it to a job daily? Will it just be something he takes out on the weekend?
Edit: Also consider the difference to insure this truck versus something else.
Old 04-10-2019, 12:02 AM
TCR's Avatar
TCR
TCR is offline
Also I think this is a bit overthinking. Highschool is the time for him to have a blast owning an old truck, learning to work on it and probably do dumb stuff just like all of us did. Plus it will show him a taste of the real world when he has to pay for gas himself. It would be good!
Old 04-10-2019, 12:53 AM
hail destroyer's Avatar
hail destroyer
hail destroyer is offline
These trucks are nearly indestructible, and are very cheap and easy to work on. An excellent choice for a kids first vehicle.
Fuel mileage is another issue. You could put the most fuel efficient engine in the world in it, it's still a big, non aerodynamic, heavy duty truck with low gears.
Quick Reply: 400 cid Fuel Mileage
