No Power 84 Bronco 351 W
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Hi I have a 1984 Bronco with a 351W and C6 transmission. The motor idles and will rev up and sounds real good but if it’s under a load it bearly has enough power to pull it self up a steep grade. Help.
I can put a ??? 30 degree dirt bank in front of it and try to climb it and it will get to the point where i can have the gas pedal to the floor and it just lugs down it doesn't spin the tires, but its like it has no torque. I don't feel any slipping or hear the motor rev up quite the opposite just lugs. It's the same on flat ground dragging a log.
does the motor rev up find while in neutral? manual fuel pumps are cheap and if its old i would start there. when was the motor tuned up last? be sure to run a regular copper plug also, no platinums or fancy plugs necessary. might be time for a carb rebuild also.
hows the tranny fluid? full? need replaced?
Had it since 1985 and always ran great. I believe the trans was serviced in 1993 and motor rebuilt in 1995. it ran good after rebuild but never really great again. it has been used very very little since then mostly around the house. after sitting around for several years with little use is when the lack of power challange started. So about 60,000 on trans and 20,000 on motor.
