rds fuel tank
Received 5,160 Likes
on
on
RDS Rectangular Auxiliary Transfer Fuel Tank 91 Gallon, Smooth Finish, Model# 71790 | Auxiliary-Transfer Tanks | Northern Tool + Equipment
they also have an install kit wich I got.
At somepoint I will have line x coat it too...
really hard to beat the deal. I stoped by a local truck parts place that wanted to sell me $2500 worth of tank, pump and eletronics. that was not in the budget.
look like all I need now are a few 3/8 nuts and bolts and may be a brass fitting or 2. to make it all work the I would like. also need to find a water trap.
I have given some thought ot also hooking up a 12v pump from a 6.0 or something to speed up the gravity feed but one step at a time. if the gravity feed works then Im just gonna leave it alone.
on
on
I recycle fuel that has metal and water contamination on a regular basis so I dont have to pay for fuel often maybe 30-40% of what I burn a year I pay for.
I have a few 100 gallons at the shop now gettting ready to pump in my ride.
I also got this thing installed tonight. not bad just about 1.5 hours to drill all the hole and run the line. the worst part was tilting the bed to istall the the fitting in to the oem fuel tank filler neck. Had I given it more thought I would have just removed the oem filler neck and drilled and welded a nut to it to install the D.O.T required rollover valve.
ya your math is bad....
How is my math bad? I just stated that because that's what it would cost me, I was unaware what type of fuel you were running, and how much you were paying for it. That's all.
on
on
the olny tools needed were a t50 for the bed bolts. a 1/4" socket for 2 hose clamps. a 7mm socket to remove the filler neck. a 13/64 drill bit to drill the mounting holes in the bed. a unibit to drill the hole for the gravity feed fuel line. a knife to cut the fuel supply line. a 8mm socket for the other hose clamps. a socket and a wrench for the 3/8" hold down bolts and of corse a drill motor for the drill bits.
