Yup got it for $300 for some needed parts on the 63. So the 65 will be the for fun fixer upper with not all the proper parts and pieces. Not the stock color either.Was going to try and find a little short wb truck like your but what the heck. Go 4x4 or go home.
Probably could of got it for $250 without the chains. I bought them to with plans to make them into one of those chain steering wheels you see in some of those low riders. Looks like I got about enough chain to make 4 steering wheels.
i would go with a flatbed as well. And if you have a welder and a angle grinder build your own. you can build one a lot better for about the same price.
Well last night I found a place near Seattle that makes flat beds out of aluminum. Look to be very light but durable. Price for a full truck short or long was around $3500 installed or they will ship a kit to you to install your self. I found that on Craigs List in the Seattle auto parts look up. Only slightly more than 200lbs vs 300 to 400lbs for steel and wood.
well a couple years ago i built one for my 64 for about 700. Mine is heavy but i wanted it that way because a little weight on the back of these trucks really don't hurt anything. Im cheap tho so i build everything.
