1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Short bed dually years?
Old 02-23-2011, 07:40 AM
Castertroy's Avatar
Castertroy
Castertroy is offline
I'm having a hellova time putting the right words together in "SEARCH" mode to find what years ford produced the dually in short bed form.
I'd really like to look for a 4x4 crew cab dually SHORT BED....but I need to know what years for produced them.
I think it was limited....like 2002-2004. Can anyone verify that?
Did ford produce shortbed dually's AFTER 2005?
Thanks soo much in advance!
Old 02-23-2011, 08:31 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
Welcome to FTE.
The only year I know of is in '01.
Old 02-23-2011, 08:34 AM
Anomic's Avatar
Anomic
Anomic is offline
Just curious what are your plans for one? Unless you are carrying led bricks bed is to small to use extra capacity and sb can be an issue with some 5th wheel applications
Old 02-23-2011, 08:46 AM
Castertroy's Avatar
Castertroy
Won't be using a gooseneck or 5th wheel application. "bumper" tow trailers are all I have. I simply prefer a shorter overall truck, but I DO want 4 full doors.
I've seen several of them around for sale...but now that I'm in the position to BUY one....can't seem to find one Just wondered what years I needed to plug into autotrader/craigs to see
Old 02-23-2011, 08:52 AM
jim48's Avatar
jim48
jim48 is offline
I know what you mean. I was dissappointed Ford's lack of shortbed dually. We went to a Dodge dealer and looked at their shortbed dually. However, Dodge does not make that truck in a supercab. My reasons for wanting shortbed dually was simply to lessen overall length. I only wanted weight carrying capacity for 5th wheel pin weight. I had a Pullrite SuperGlide. So, didn't have to worry about hitting cab. Anyhow, with all that said after 7 happy years with last truck (04 F250 SB,SRW,4x4). I ordered F350 Lariat Chassis cab 2WD and gave up wishing for Ford SB. You could always go shortbed F350 SRW, sell bed and do flatbed. But if you do F350 dually and sell bed it will still be longbed frame. I wrestled with all that for over two years. I have 275 miles on new truck, just getting some breakin miles on engine while waiting for aluminum bed to be made. Hope you find a solution to your needs.
Old 02-23-2011, 08:57 AM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
Ford did produce short bed duallys after 2005, here is some proof...
Old 02-23-2011, 09:10 AM
Gofigurethis_01's Avatar
Gofigurethis_01
Gofigurethis_01 is offline
Most definitely, I have seen them on the web and one in person on a dealer lot.
Try searching with f350 156 drw, where 156 is the wheelbase of a crew cab short box.
Seems to me there was alot of '99-'04, only seen a couple '05-'07. I'm sure the truck you want exists, you just have to find it.
Old 02-23-2011, 09:38 AM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
I see quite a few here in FL. Not too many new ones, but they are out there.
Old 02-23-2011, 11:11 AM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
They produced them through the 2008 model year. They were discontinued sometime in late '08 - early '09. I know there were 2008 models but I think that was the last year......no 2009s.
Old 02-23-2011, 12:01 PM
BigPigDaddy's Avatar
BigPigDaddy
BigPigDaddy is offline
I know they made them as early as 2000 because there is a guy selling the bed off one locally.
Old 02-23-2011, 01:34 PM
brd7666's Avatar
brd7666
brd7666 is offline
Old 02-23-2011, 02:34 PM
Byram's Avatar
Byram
Byram is offline
If the second one had a stick in it --- I'd go buy it for a ranch /haul truck - although lifted a little too high for me..
Old 02-23-2011, 02:46 PM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
I thought they made them right up until 2010?
Old 02-23-2011, 03:41 PM
powerstroke72
They got discontinued either at the end of the '08 model year or early in the '09 model year. The 2010 order guide doesn't show them as available.
Old 06-03-2011, 09:19 AM
Castertroy's Avatar
Castertroy
FOUND ONE!
The perfect one!
Quick Reply: Short bed dually years?
