Welcome to the Arizona Board & FTE. But with no info it is pretty hard to help you.
Craig
Kerrmy thanx for replying. One day it took on gas ...next day it wouldn't. filler tube is not clogged, hose to tank is not obstructed. Will take a little at a time (20 minutes for 3 gallons), but also leaks out of something up by motor as I'm putting it in. Someone mentioned something about a "rollover valve". Any clues you or freinds may be able to give me? Craig
Maybe your tank has a limiter on it--like the credit card charge limit things at the pump--and it's rejecting gas at more than $3.00 per gallon.
Joe
Hey Joe, I wish there was a limiter on the pump that restricted over $1.50/gal charge.
To Craig, What years, make, model etc. It could be a plugged vent tube if it is a FI motor it could be other things. We will be glad to help just give us the info on what your vehicle is.
