truck goes then no power?
I am working on a friends 2003 6.0. The truck has 123,000 miles. The problem that it is having is that when accelerating from a stop it accelerates until it gets to about 3000 rpms. Then it feels like it has no power and won't shift. If I let off the accelerator pedal it will shift and then accelerate again to about 3000 rpms not shifting with the feeling of a loss of power. It will do this in all the gears. I just removed the turbo and did the cleaning procedures. I did the vgt relearn procedure following the cleaning. The truck has no codes.My friend said that he replaced both fuel filters about 6 months ago. Any help would be appreciated. Thanks
go to the dealer and get the new fuel pressure regulator kit.I just did mine last night and it fixed my problem.
Search my posts and see the problems i was having they are just like yours.
Get the kit or get a ball bearing that is .156 dia to .1875 dia remove cover on sec fuel filter remove the 4 screws pull spring insert ball and reinstall spring plat and fule lines that will also fix and itll be a cheap fix fi he wants to drop the 80.00 for the kit then he can once you fixed it with the ball bearing
seebeexee
06-09-2013 09:32 PM
custom69
08-17-2005 03:54 PM
Crazyromi
11-04-2003 08:54 AM
