1997 F350 7.5L has rough idle when cold
Hi,
All of a sudden, today, when I started my truck after sitting about 36 hours, it ran very low idle ( 500 RPM), and died. I started it again ( started right away) and held the accelerator down at about 1000-1200 RPM for a few minutes. Engine purred at this RPM and sounded normal. When I let off the gas, the low idle returned, but did not die. After 15 minutes of driving, idle was normal at 800 RPM.
Spark plugs, distributor, cap, rotor, wires, fuel filter replaced last year. Recent vacuum hose repair. Recently replaced battery.
Where do I start looking???
Thanks Laura
p.s. I can't ask my husband cause he will start yelling at me to get rid of the truck!
Thanks Laura
Ford Fuel Injection » Engine Coolant Temperature Sensor (ECT) Here is a link on how to test the Engine Coolant Temperature sensor. I think that is where I would start.
Now I notice, when in park, the idle fluctuates slightly. I got an oil change today and the tech tried to read the codes, but he has to set up his computer different to do so. He asked if I could come back in the morning ( they were lined up for oil changes) and I said I would. He also suspects a sensor ( IAC or TPS).
I did recently have some of my vacuum hoses replaced due to leaks.
Thanks
Laura
Thanks
Laura
Greasy89
34
07-28-2019 05:48 PM
LARIAT 85
05-07-2017 04:17 PM
