F150 won't start after power wash the engine
My friend had his 2008 F150 L:imited washed and they apparently decided to pressure wash the engine.
Now the check engine light is on, and it runs like crap. At least yesterday, today it won't even start.
Any ideas what broke? The codes said something about the throttle body?>?
You may need to open EVERY connector and spray them with WD-40.
The WD stands for WATER DISPLACEMENT.
The electrical system is shorting.
Use a hair dryer to further dry the connectors.
Use an air compressor to blow the water out of the spark plug valleys.
Park it in a heated garage and wait for it to dry out.
Use Bulb Grease when reconnecting things to prevent corrosion.
NEVER, EVER, USE HIGH PRESSURE TO WASH AN ENGINE!!!!!
on
I second the idea of opening every connector. But don't use WD40. WD40 is not made for electrical items. It will cause more electrical problems since it is conductive.
Use a product called CorrosionX. It is made to be used on electrical components. We use to displace water and clean our SCADA modules when they get exposed to high humidity or water. We have also used it on live 480VAC contactors.
It non conductive and non destructive.
CorrosionX
Here a great demo of its electrical application.
CorrosionX Demo
CorrosionX
CorrosionX Demo
My4Fordtrucks
05-02-2017 06:37 PM
kyacklich
27
07-09-2014 05:50 PM
