1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Should I add an additional cooler?
Old 02-10-2011, 02:22 PM
Junebug_'s Avatar
Junebug_
Junebug_ is offline
My Expe, see my signature, has the factory Heavy Duty Tow Package (and factory 3.55 gears for some reason, I sure wish they were at least 3.73) anyway it has the tow package with the bigger radiator, motor oil cooler, and transmission fluid cooler. We primarily use the vehicle to tow our 7000 lb TT on weekends to local campgrounds and the occasional 300 miles trip out of state. This summer we plan on camping in more mountainous areas and I am concerned about the transmission overheating. Should I add an additional cooler in series with the factory transmission cooler, or will the factory cooler be sufficient?
Old 02-10-2011, 04:03 PM
Big Greenie's Avatar
Big Greenie
Big Greenie is offline
Temporarily Deactivated
Transmission temperature gauge, that is what you need. The ONLY way to know if you need more cooling capacity is to monitor the temp. I seriously doubt you need more capacity.
No matter how large a cooler you fit, it is still very possible to cook a trans towing in the summer, on long grades etc. If you have a temp gauge you know when it is time for a cool down.
Old 02-10-2011, 07:37 PM
Junebug_'s Avatar
Junebug_
Junebug_ is offline
Any recommendation on a guage manufacturer and sending unit install point?
Old 02-11-2011, 06:25 AM
aba4430's Avatar
aba4430
aba4430 is offline
Originally Posted by Junebug_
My Expe, see my signature, has the factory Heavy Duty Tow Package (and factory 3.55 gears for some reason, I ....
Just an FYI - in 2000 at least, a 3.73 was not offered unless you ordered it with a high altitude emissions package. I have the 3.73 on mine. I had it special ordered through the Ford dealership, with the emissions package.
Old 02-11-2011, 10:46 PM
Junebug_'s Avatar
Junebug_
Junebug_ is offline
Thanks for the info ABA!
06FUN
10-29-2016 07:53 AM
tfdcc
2011 to 2019 Explorer
22
08-11-2016 04:22 PM
NLPRacing
29
11-07-2015 05:46 PM
meborder
10-08-2015 08:41 AM
Wingdreamer
2009 - 2014 F150
15
05-15-2015 09:20 AM
Quick Reply: Should I add an additional cooler?
