1994 E-350 7.5L 460
1994 E-350 7.5L 460
Howdy,
Have not posted in a looong time. Just got a motor home that is based on a 1994 Ford E-350 7.5L Gas engine. It has 41K miles on it. I just drove it cross Country (well, from Maryland to Sonora, Mexico) and it performed like a champ. Question, now the Vent/AC/Heater blower does not work. When I turn the speed dial nothing happens. It just worked, now it does not. Checked all the fuses and they are a go. Anyone know what to look for? I have seen threads on Vacuum lines, etc but I need Pictures (No Marine jokes please ;-))
for this particular engine.
Thanks in advance,
Semper Fi
Thanks in advance,
Semper Fi
Is the blower electrical working? Could be one of the actuators for the doors under the dash. Also you might want to visually inspect the lines under the hood. You might get a Haynes manual at your local parts store or on line they have pretty decent pictures. Sorry I could be much more help
Might first start by checking the blower motor relay and the blower motor itself---both frequent causes of no air movement.
Run a suitable large wire directly from the battery to the single post on the blower motor, "bumping" it to see if it runs---if not the motor is bad. From here check the relay located inside the large under-hood box containing numerous relays.
This would be an easy start and tends to be the most experienced problems especially considering the age of your van.
Hope this helps even a little!
It could be the blower motor relay is bad.
Did you check Fuse "F" in the engine compartment fuse relay box?
Engine compartment fuse relay box:
1994 E Blower & Horn Relays, the Blower relay is the one with these wires:
1. Yellow wire with a red stripe.
2. Yellow wire
3. Orange wire with a red stripe.
4. Black wire.
2. Yellow wire
4. Black wire.
I would like to label it for others.
Is fuse #9 good in the Interior (dash) fuse panel good?
If you ground the Orange wire with a black stripe at the blower motor does the blower motor run?
In other words does the Orange wire with a red stripe leaving the blower motor relay have power on it when the key is on and the selector switch is on floor?
