What mods do you wish you hadn't done?
#46
#47
OK let see.. PO... screw up, so had to did a valve job... PO put on wrong valves seals... They put in to large of a cam for the motor... so new cam and lifters... Old ones trashed... rejet the carb for the new RV cam... Newest things, Radiator cap is a 30lbs... REPLACE.... solder up leaks in radiator.... A friend is giving me a 31 gal fuel tank out of a Suburban.... What's next?
#50
#51
#53
I live in the Seattle area... we get about 7-8 months a year of rainy weather. I wish I had done the bare minimum to get my truck on the road, so i could at least drive it, then use that rainy season every year to wrench on it.
My truck is looking awesome, but I'm 6 years in and it still isn't drivable. Funny thing is that I did drive it home when I bought it.... granted it needed work.
#54
When I was a teenager, I installed a sun roof. You guys remember the smoked plexiglass, bubbled up sun roofs that were popular in the 70s? I think most conversion vans had them for a while.
Anyway, the sun coming in made the black truck even hotter, it always seemed to leak, and the truck didn't really need the added air flow since it had the cowl vent to inflate the pants legs.
One day I forgot to lower it before I backed into the garage. That pretty much took care of it. I learned my lesson, filled the hole, and lived much better without it.
#55
#56
gas tank
Do you know what mustang tanks will fit for a 56F100? i found one on a local website for $20 says it fits 79-93 mustangs.
#57
I think this article goes in depth on the gas tank choices for
our truck. Seems to recommend 64-68 Mustang/Cougar 16 gallon tank,
69 Mustang 20 Gallon, & 70 Mustang/Cougar 22 gallon. I went with the 1970 to maximize range & it was a bit narrower than the older mustang tanks & fits between the rails easier.
You would want to measure your tank space out back then pick the tank that fits best. My Previous Owner had done a lot of work putting in a
tow hitch & I had less room than normal.
INSTALLING A MID-60's Mustang Tank in a '53 F-100 truck
gastanks.com
Ben in Austin
gastanks.com
Ben in Austin
