Here are my codes! Please Help!
thank you, I have seen the codes, my questions is? where should I start? should I replace the EGR and the Oxygen sensor? I have my Egr vacuum hose disconected and this is the only way for my turck to run smooth. But it will die if the RPMs drop too fast, like when i put it in neutral while driving. I have a 5 speed.
No, not a good idea to throw money at her, you need to test the different faulted components. The first one would be the fuel, hook a fuel gage to the fuel rail on the engine. Since I don't know your engine type, you will need to get those specs. On my motor, key on, not started should be 35-45 psi. Check this link out for info on those sensor problems.
Ford Fuel Injection » Home
