fanbelt diagram 6.9l
Old 02-04-2011, 09:34 PM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
so every time i try to get fan belts for my truck im told there should be only 3... but mine has 4..... anyone have or know where to find a belt diagram? i do not have ac and do have a vacuum pump
Old 02-04-2011, 10:02 PM
IDIDieselJohn's Avatar
IDIDieselJohn
IDIDieselJohn is offline
Theres so many ways to put belts on these.
My 7.3 with no A/C
First belt closer to radiator goes from: Crank to Fan, from Fan to P/S pump.
2nd belt (middle one) goes from crank, fan, then vacuum pump
3rd belt closer to block goes from crank, fan then Alternator.
My Alt has a dual belt pulley but haven't really used it.
On my Factory (not dealer) A/C 6.9
First belt closer to radiator goes from crank, fan then A/C compressor
2nd middle belt goes from crank, fan, then P/S pump
3rd belt closer to block goes from crank, fan, then Alternator
Then theres a 4th small belt from the Alt that goes straight down to the vacuum pump.
I am pretty sure that's how they are from the factory.
Old 02-04-2011, 10:18 PM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
I have nearly identical motor packages and identical belt runs.
-Enjoy
fh : )_~
Old 02-04-2011, 11:33 PM
Midnite1987
ok thats how mine is - the ac part i thought maybe someone changed up the belts as 1 is a cog not a smooth belt
Old 02-05-2011, 12:43 AM
LCAM-01XA's Avatar
LCAM-01XA
LCAM-01XA is offline
Originally Posted by IDIDieselJohn
My 7.3 with no A/C
You got a 2-groove P/S pump pulley, right? And you only use its front groove, the rear one is empty like the front groove on the alt pulley? On all non-A/C trucks I've ever seen both the front and the middle belts go crank-water-P/S (so the P/S pump has two belts driving it), and the vacuum pump gets driven off the alt pulley like they are in the factory-A/C setups... Which would actually be great for hydroboosted trucks cause there the P/S pump serves double-duty, but for the vacuum-assisted trucks what you describe sounds like a better idea.
Old 02-05-2011, 12:59 PM
IDIDieselJohn
Yup, both Alt and P/S pump on the 7.3 have dual belt pulleys.
It's my dad that set 'em up like that on the 7.3 when he changed for the very first time the belts on it. He thaught it would be a better settup than having that little belt drive the Vacuum pump from the Alt. He found it pretty useless to have 2 belts driving the P/S pump for his application.
So each acceserie has it's own belt off the crank/fan.
Old 02-05-2011, 11:57 PM
87crewdually's Avatar
87crewdually
87crewdually is offline
Like this: 4 belts and NO A/C
Old 02-07-2011, 04:17 AM
LCAM-01XA's Avatar
LCAM-01XA
Oh, I see a saginaw pump on that pic
Old 08-25-2012, 01:25 PM
FireKracker50's Avatar
FireKracker50
FireKracker50 is offline
What engine is this a picture of?
Is this a crate motor with banks sidewinder already installed?
I have an 84 F250 with 6.9L naturaly aspirated.
just wondering what my opions are.
Old 08-25-2012, 07:50 PM
87crewdually
It's a pic off of Banks website. It was used for advertising the Sidewinder System.
Fitzgerald_welding
10-02-2019 01:56 PM
halfbolt
12-09-2015 04:22 PM
B_line66
08-22-2014 07:13 AM
luv2sled
07-06-2003 09:46 PM
Quick Reply: fanbelt diagram 6.9l
